Topic: 4 Wheel Autonomous Car Code (Read 1 time) previous topic - next topic
ilikechubs
I am using a adafuit motor sheild, 4 wheel base, 4 pin ultrasonic distance sensor, with an Arduino Uno.  I am not using a servo but I am willing to. I have the trig pin on 10 and the echo pin on 2 I need a better code. this is the code I am currently using, which is not working well:
Code: [Select]
#define trigPin 10
#define echoPin 2
#include <AFMotor.h>
int sound = 250;
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
 Serial.begin (9600);
 pinMode(trigPin, OUTPUT);
 pinMode(echoPin, INPUT);
 motor1.setSpeed(200);
 motor2.setSpeed(200);
 motor3.setSpeed(200);
 motor4.setSpeed(200);
 motor1.run(RELEASE);
 motor2.run(RELEASE);
 motor3.run(RELEASE);
 motor4.run(RELEASE);
 uint8_t i;
 long duration, distance;
 digitalWrite(trigPin, LOW);
 delayMicroseconds(2);
 digitalWrite(trigPin, HIGH);
 delayMicroseconds(10);
 duration = pulseIn(echoPin, HIGH);
 distance = (duration/2) / 29.1;
 if (distance <= 3) {
   motor1.run(BACKWARD);
   motor2.run(BACKWARD);
   motor3.run(BACKWARD);
   motor4.run(BACKWARD);
   delay(10);
 else {
   motor1.run(FORWARD);
   motor2.run(FORWARD);
   motor3.run(FORWARD);
   motor4.run(FORWARD);
   delay(10);
I would like the code to include left, right, forward and reverse.
Thank you
-Ben
PaulS
Quote
It does something. You have not explained what it does.
You expect it to do something. You have not explained what you expect.
You have not explained what "not working well" means. To me, a working well is one that has water. A "not working well" would be a dry hole. Somehow, I expect that the phrase has a different meaning to you.
ilikechubs
My arduino is not sensing the distances or determining whether to go left, right, forward, and reverse.  Two motors never spin.
jremington
The usual approach is to put in a bunch of print statements to see where things are going wrong. For example, after these two lines:
Code: [Select]
print out "distance" so you can see if it makes sense.
