Topic: Controlling 12 - 24 LEDs: TLC5940, TLC5947, ... (Read 894 times) previous topic - next topic
Zealot
May 12, 2015, 09:26 am Last Edit: May 12, 2015, 01:07 pm by Zealot
I'm just starting with LEDs. First I thought I use a SN74HC595N shift register, but then I found the TLC5940 (16-Channel LED Driver w/EEprom DOT Correction & Grayscale PWM Control)
What I want to achieve: Control 12 (maybe later 24) LEDs, (turn on/off and dim them).
TLC5947 (has 24 channels) would be perfect imho. But there is no DIP package - and the only breakout board I found is from Adafruit - and pretty expensive.
Are there alternatives?
Grumpy_Mike
Quote
Well if $15 is considered expensive what budget are you on?
The alternative is to buy an undedicated breakout PCB from eBay and solder it on yourself, it is not hard.
Zealot
Compared to the 5$ of the chip $15 is quite a lot. And the Adafruit breakout board has stuff that I don't need (e.g. the voltage regulator).
Grumpy_Mike
If you can't solder a surface mount chip then the $10 is for some on to do it for you.
An other alternitave is to use the 5mm neopixels.
vile
In my project, I first used the TLC5940, but then I found the PCA9685 which I think is much easier to use, since it communicates via I2C and adafruits library works great.
I bought some PCA9685 in TSSOP28 package from ebay (Link), adapters (Link) and soldered the chips as shown in this video: Drag soldering SMD parts with a flux pen.
For my project, this is the best solution.
Zealot
#5
May 13, 2015, 09:25 am Last Edit: May 13, 2015, 09:26 am by Zealot
Thanks a lot for your post! The PCA9685 indeed seems to be a very good choice:
- 2.3 V to 5.5 V
- inexpensive (under 2$ from Farnell)
- TSSOP28 (TLC5947 has TSSOP32 and the adapters are way more expensive than TSSOP28 ones)
- I2C
It's just: I've never hand soldered SMD before. Dave Jones has a very nice video covering different techniques: https://www.youtube.com/watch?v=b9FC9fAlfQE. So I might just give it a go.
