Topic: Lots of LEDs in series (Read 712 times) previous topic - next topic
Zealot
I have a general problem understanding how Neopixels work. I did read the Uberguide - but found no answer.
Having 10 LEDs, say 4V each, in series, I'd expect to need 40V.
How is it possible to drive 10, 20, 100, ... Neopixels with only 5V?
ieee488
#1
May 14, 2015, 07:20 pm Last Edit: May 14, 2015, 07:21 pm by ieee488
A RGB LED is "essentially" 3 LEDs in parallel.
Not sure what you are asking.
Neopixels need to be powered by 5V.
Zealot
I thought that this Neopixel rings, strips, ... connect the LEDs in series - hence my confusion.
Just found this image:
Are all the Neopixels connected in parallel (not serial as I assumed)?
So basically a Neopixel strip looks like this?
CrossRoads
A Neopixel is a controller and an RGB LED.
Each one has power, Gnd, Data In, Data Out.
Power passes thru (2 pins)
Gnd passes thru (2 pins)
Data In is an input (1 pin)
Data Out is output (1 pin)
So Power, Gnd are in parallel to all pixels, and Data is daisychained along.
