Topic: PCA9698  (Read 4653 times) previous topic - next topic
new1111111
I'm try to find a easy way to control a pca9698 ? I have tried a few diff lib but none are setup to handle all 40 bits. PLEASE HELP!
robtillaart
what is a pca9698?
do you have a datasheet or other link?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
new1111111
www.nxp.com/documents/data.../PCA9698.pdf
Headroom
So what libraries have you tried ?
Some links would be helpful. If there are libraries that successfully work with this chip then extending those to work with all the IO may not be such a difficult thing.
http://trippylighting.com
http://ledshield.wordpress.com/
new1111111
I get the xio working but you have to call the io pin to a output and back to a input or it will stay high.
Grumpy_Mike
Quote
What is an xio?
Quote
Please post your code.
new1111111
#7
Jun 14, 2015, 07:21 pm Last Edit: Jun 14, 2015, 07:24 pm by new1111111
The I2C-XIO: I2C 40-Channel Digital I/O Expander.Do still want to see the code?
Grumpy_Mike
new1111111
it's not pretty this is what I used to test NPX PCA9698 (OM6281)
#include <XIO.h>
#include <Wire.h>
XIO xioBoard;
  // initialize serial communications at 9600 bps:
  Wire.begin();
    xioBoard.begin(LOW, LOW, LOW, -1, -1);
//xioBoard.xioPinMode (XIO_PIN_D0,  OUTPUT);
xioBoard.xioPinMode (XIO_PIN_D1,  OUTPUT);
  do
  xioBoard.refreshIO(); //RESET PIN TO OFF
  xioBoard.xioDigitalWrite(XIO_PIN_D1, HIGH);
   delay(1250);
    xioBoard.xioDigitalWrite(XIO_PIN_D1, LOW);
    delay(250);
    xioBoard.refreshPinModes();
  } while(1);
Grumpy_Mike
When you post code you should put it between code tags, use the </> icon. Read the how to use this forum sticky.
Why the do .... while structure? It is totally unnecessary.
Where did you get the XIO.h library, I found one but it also had an other file to include, is it available in one place?
At a guess I would say the code should be this, but without the library I can't tell for sure:-
Code: [Select]
#include <XIO.h>
#include <Wire.h>
XIO xioBoard;
  Wire.begin();
    delay(1250);
    delay(250);
Note it is not all stuffed with blank lines.
new1111111
#11
Jun 19, 2015, 01:31 am Last Edit: Jun 19, 2015, 01:35 am by new1111111
OK, I looked every where trying to find how to post the code thanks. it had a serial read of some port pins there. I had some problems switching from bank to bank sorry about the blank lines the setup this chip is large.What is the name of the other file?
