Topic: MQ 135 value  (Read 2616 times) previous topic - next topic
weske2000
Hello i,m try mq 135 air sensor
But it read 0,02 ppm ?
#include "MQ135.h"
#define ANALOGPIN 0
float airthreshold[3] = {
  400, 400, 800};
  // Initialize the gas Sensor
MQ135 gasSensor = MQ135(ANALOGPIN);
  // start the LEDs
  //Set up the serial terminal
    float ppm = gasSensor.getPPM();
     Serial.print(" CO2: ");
  Serial.print(ppm);
  Serial.println(" ppm ");
This is the code
Is 0,02 ppm good reading
Thanks
robtillaart
moderator: please use code tags - and use CTRL-T in the IDE for proper indenting
also a link to the library used will be helpful
Quote
What did you expect? is it too low/high
What does the datasheet of the sensor describe as unit?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Torrettoe
This website is a good website. Has experienced an increase
lmaraf
hi, this solves the question:
https://hackaday.io/project/3475-sniffing-trinket
