Topic: Tips on making a robot which presses a button every 2 seconds: (Read 783 times) previous topic - next topic
Vaksky
Any tips on the equipment or steps/readings I would have to do in order to make this possible.
Also, what if the on and off buttons are different which the Arduino must press are different. For example:
Instead of a button looking like this:
(on:off)
It is two buttons:
(on)
and 3 centimeters below
(off) .
Any help is greatly appreciated
AllSystemGO
The
Quote
is it because IT IS 2 different buttons or not?
I would probably create a mount for a solenoid, http://www.adafruit.com/search?q=solenoid&b=1, that would trigger every x second to push on the button. Two different mounts would be required if you have 2 different buttons.
Like I said on different posts, I might be wrong on my approach but I would try that.
Have fun and I hope it helps
J...
JimboZA
Quote
Or look to some linkage arrangement with a servo.
Quote
Either way, the timing between the pushes can probably be handled using the BlinkWithoutDelay approach, which frees up the processor if there are other things to do. (ie, don't use delay() )
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
oric_dan
I don't suppose this is what you want [sorry for the joke, but too good to miss - it gets better towards the end].
https://www.youtube.com/watch?v=-PqcCjFaf3I
In any case, this is one way to flip a switch mechanically - he's using an RC servo, which is very easy to control with an Arduino board.
http://www.lamja.com/?p=451
