Topic: Electronic Blogs: which ones do you follow? (Read 933 times) previous topic - next topic
Zealot
May 20, 2015, 01:29 pm Last Edit: May 20, 2015, 01:33 pm by Zealot
I recently discovered a couple of Electronics blogs - and I love them (it also helps me to reduce the number of dumb questions that I ask here on the forum  ;)).
Dave Jones (EEVblog): https://www.youtube.com/channel/UC2DjFE7Xf11URZqWBigcVOQ
Afrotechmods: https://www.youtube.com/channel/UCosnWgi3eorc1klEQ8pIgJQ
mjlorton: https://www.youtube.com/channel/UCOTPsWDzNAosVd6vc3pCPHQ
The Ben Heck Show: https://www.youtube.com/channel/UChturLXwYxwTOf_5krs0qvA
Dorian McIntire: https://www.youtube.com/channel/UC_O_niZqGWMOUbX37gmqGHw
w2aew: https://www.youtube.com/channel/UCiqd3GLTluk2s_IBt7p_LjA
What else is there? Which ones would you recommend?
CrossRoads
#1
May 20, 2015, 10:17 pm Last Edit: May 20, 2015, 10:18 pm by CrossRoads
I don't follow any. Not enough hours in a day.  Being an Electrical Engineer I can also figure out most things I need, and just need some occasional software help.
raschemmel
#2
May 21, 2015, 03:52 am Last Edit: May 21, 2015, 04:15 am by raschemmel
Electronic blogs, which, for the most part , are tutorial in nature have their place. If you are new to electronics they can help get you up to speed, however, your endgame goal should be to learn how to properly research your project , without resorting to blogs or Vlogs.  Obviously, having a BSEE pretty much means you either know the information already  or you know where to find it. Speaking as a technician, rather than an engineer, with only a 3-yr degree (BSEET: Bachelor of Science of Electronic Engineering Technology), I would say that close to 90% of what you need to know in electronics can be found in datasheets, and another 5% can be found in App Notes. What can't be found in datasheets and app notes can probably found with Google. As a general rule, I would say that reading tutorials and blogs is not a substitute for knowing how to read a datasheet. Tedious though it is, (especially when you get into how to read registers in an I2C chip) it is nevertheless far more productive to wade through a long datasheet (like the ATmega328 datasheet (629 pages) ) until you have overcome your fear of reading datasheets , than to spend all your time watching tutorials (unless they are about how to read datasheets). I would suggest reading the section about the Timers.
Quote
16.3 Accessing 16-bit Registers
The TCNT1, OCR1A/B, and ICR1 are 16-bit registers that can be accessed by the AVR CPU via the 8-bit data bus. The 16-bit register must be byte accessed using two read or write operations. Each 16-bit timer has a single 8-bit register for temporary storing of the high byte of the 16-bit access. The same temporary register is shared between all 16-bit registers within each 16-bit timer. Accessing the low byte triggers the 16-bit read or write operation. When the low byte of a 16-bit register is written by the CPU, the high byte stored in the temporary register, and the low byte written are both copied into the 16-bit register in the same clock cycle. When the low byte of a 16-bit register is read by the CPU, the high byte of the 16-bit register is copied into the temporary register in the same clock cycle as
the low byte is read.
Head spinning ? Getting dizzy ? Feel like your banging your head against the wall ?
Enter the Application Note
Still confused ?
Time to turn to Google.
Google search
tutorial found using google
Does this make more sense ?
Quote
We've set Timer1 to interrupt on an overflow, and let's assume we're using an ATmega328 with a 16MHz clock. Since Timer1 is 16 bits, it can hold a maximum value of (2^16 - 1), or 65535. At 16MHz, we'll go through one clock cycle every 1/(16*10^6) seconds, or 6.25e-8 s. That means 65535 timer counts will elapse in (65535 * 6.25e-8s) and our ISR will trigger in, oh… about 0.0041 seconds. Then again and again, every four thousandths of a second after that. Oops. At this rate, we probably won't even be able to detect blinking. If anything, we've created an extremely fast PWM signal for the LED that's running at a 50% duty cycle, so it may appear to be constantly on but dimmer than normal. An experiment like this shows the amazing power of microprocessors - even an inexpensive 8-bit chip can process information far faster than we can detect.
Tutorial #2 found using Google
For all practical purposes you will be an electronics cripple until you have gotten to the point where you are ready and willing to jump into an unknown datasheet feet first , rather than spend all night googling for tutorials on how to use the chip.
In short, there is a special HELL for people who don't read datasheets. It is a place where nothing works and everything smokes when you turn on the power...
JimboZA
Can't beat Dave Jones for sheer entertainment though....
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
keeper63
I've always like the Electro-Tech forums:
http://www.electro-tech-online.com/
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
