Topic: arduino isp error burning bootloader to fresh atmega32u4 (Read 4937 times) previous topic - next topic
2kohm
Hello Community,
i designed my own arduino leonardo board with an atmega32u4-au
the pcbs and the circuit are fine! i have one working board so this is no HW issue.
i cant upload the bootloader ! but with one board in the same setup it worked perfectly!
soldering checkt 20000% DMM tests etc...
i googled for hours...
now i get this error with all boards  :(
Bootloading Problem:
ArduinoMega2560 = ISP
Arduino IDE 1.0.3
Source atmega32u4-au ISP
Code: [Select]
bin kohm$ ./avrdude -C avr/etc/avrdude.conf [b]-v -v -v -v -F -t -u -V -B 1000 -patmega32u4 -carduino[/b] -P/dev/cu.usbmodem1451 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xcb:m -Uhfuse:w:0xd8:m -Ulfuse:w:0xff:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/kohm/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem1451
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         Setting bit clk period        : 1000.0
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       1024    8      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [00] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [00] . [00] . [00] . [00] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [08] . [d7] . [a0] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
avrdude: 1 bytes of lfuse written
avrdude: Send: Q [51]   [20]
  Thank you.
:smiley-confuse:
Peter_n
Could you try the newest Arduino IDE 1.6.4 and burn the bootloader from within the Arduino IDE.
Are you running this in linux ? I hope you don't use the Arduino IDE 1.0.3 from the repositories.
Do you have something else to program a ATmega chip ? An Arduino Uno perhaps ? I have USBasp version 2, but I had to add a rule for that in linux.
2kohm
hi peter,
i try this in macosx
it is the old release 1.0.3 and with one of my boards all works!?!
this is crazy....
more -v-v debug infos
i use my atmega2560 as arduino isp
http://pastebin.com/1hKQ1x0q
Peter_n
The communication is going wrong. Reading the lfuse, hfuse, efuse return all three only zero. That is probably a MISO or MOSI signal going bad.
It could be a very thin copper trace that shortcuts something. Or there is something that has a larger capacitance. Of a voltage level from a voltage regulator is slightly different. Or the ATmega32U4 is damaged. Or not enough decoupling capacitors. Or a bad ground wiring.
My best advice is to change as much as possible. An other programmer, other computer, other cables, and so on.
[ADDED] Maybe I'm wrong, and it is as Isaac96 writes in Reply #4. The newer versions of avrdude read the chip settings from the avrdude.conf file.
Isaac96
Looks like you don't have a avrdude.conf file or you have the wrong path for it. You could try reburning the other board you have to see if it works. The comms appear to be all right, but your ISP isn't reading the device signature.
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
2kohm
thank you !!!
i get the same error also inside the arduino IDE if i hit "Burn bootloader"
so i think thr avrdude.conf is ok?
yikies! invaild device signature ;(
i check my HW setup today but again, one off my boards work!
i ordered and USB ISP programmer at ebay and check this also!
what should be inside the avrdude.conf?
2kohm
avrdude is ok, i reuploaded the isp sketch to my mega2560. all ok
maybe i have the wrong commandline?
i read about 100000 times to NOT use the -F flag in avrdude but with -F and -V it looks good except for the fuses ;(
is there any wayni can burn the leonardobootloader using FLIP with Win?
everytime i try to select the HEX file, flip says, wrong checksume, to big file???
2kohm
my board layout
http://www.mikrocontroller.net/attachment/257426/test.jpg
2kohm
i checkt all connections, all ok...
somtimes if i touch the UCAP 1uf i get device signature 0xffffff and not 0x0000
changed usb cabel usb port another pc..
this is wired....
Peter_n
You should never use the -F flag. The -v is only extra debug output and that is okay.
When for example a new microcontroller is used, say ATmega328Px and the avrdude only knows the ATmega328P then the -F could be used if they are identical. You should try to find what causes the mismatch of the signatures.
Isaac96
Definitely do not use -F ! It takes away useful info. It does look like you have avrdude.conf. If your device signature returns all zeros, then that usually means a comms problem. You said you have another 32u4 board- can you try reburning the bootloader on that one?
2kohm
thanks for the hint! no more -F
i have some teensy boards, try to flash one with my mega2560 via isp.
i dont want to kill my working prototype but can i not coppy the working chip to another??
Isaac96
You can probably move the chip, if that's what you need.
2kohm
sorry for my bad english ;)
coppy the Software from my working prototype (bootloader and prgramm) in one hex file to another atmega32u4 with Atmels FLIP ?
in flip i see the chip via usb.
but the bootloader is the atmega32uf-DFU?
2kohm
i cant flash the teensy via my atmega ISP - cstk500 not in sync...
Code: [Select]
i soldered an new prototype, same error :-(
avrdude -c vrdude.conf  -v -v -v -v -pm32u4 -cstk500v1 -P/dev/tty.usbmodem1451 -b19200 -Ulock:w:0x3F:m -Uefuse:w:0xcb:m -Uhfuse:w:0xd8:m -Ulfuse:w:0xff:m
avrdude: Version 6.0.1, compiled on Dec 16 2013 at 17:26:24
        System wide configuration file is "/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf"
        Using Port                    : /dev/tty.usbmodem1451
        Using Programmer              : stk500v1
        Setting bit clk period        : 20.0
        PAGEL                         : PD7
        BS2                           : PA0
        RETRY pulse                   : SCK
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
          eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
        Programmer Type : STK500
        Description     : Atmel STK500 Version 1.x firmware
        Hardware Version: 2
        Topcard         : Unknown
        Vtarget         : 0.0 V
        Varef           : 0.0 V
        Oscillator      : Off
        SCK period      : 0.1 us
 . [04] . [d7] . [a0] . [00]   [20]
Reading |                                                    | 0% 0.00savrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
Reading | #################                                  | 33% 0.03savrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
Reading | | 100% 0.05s
avrdude: Device signature = 0x000000 (retrying)
Reading | #################                                  | 33% 0.04savrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
Reading | ################################################## | 100% 0.06s
Reading | ################################################## | 100% 0.05s
avrdude: Yikes!  Invalid device signature.
        Double check connections and try again, or use -F to override
        this check.
avrdude done.  Thank you.
