Topic: 88 MILES PER HOUR!!!! LED 3DIGIT 7SEGMENT 12PIN DISPLAY (Read 3373 times) previous topic - next topic
Marmotjr
WARNING
Do Not connect this circuit to a FLUX Capacitor !
I don't see why not.   It'd be my first step.   I'd go find a book on sports results, and well....
JONE5Y
I'm realizing I just really need someone to write the program for me so I can finish the fabrication of the prop.
I know my strengths and programming isn't one of them so I am going to post my need for a programmer in gigs and collaborations.
Thanks for the advice thus far.
Paul__B
WARNING
I would not advise using a breadboard though - you might be stuck and we would never see you again ...
larryd
Quote
And if you keep your mom and dad apart then what good is it?
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
HazardsMind
Give this a try and let me know what it does as I can't test it.
Code: [Select]
#include "SevSeg.h"
SevSeg sevseg; //Instantiate a seven segment controller object
  byte numDigits = 3;
  byte digitPins[] = {2, 3, 4};
  byte segmentPins[] = {6, 7, 8, 9, 10, 11, 12, 13};
  sevseg.begin(COMMON_ANODE, numDigits, digitPins, segmentPins);
  sevseg.setBrightness(90);
  static unsigned long timer = millis();
  static int deciSeconds = 0;
  if (millis() - timer >= 100UL)
    deciSeconds++;
    if (deciSeconds > 880) // Reset to 0 after counting for 1000 seconds.
      deciSeconds = 0;
    sevseg.setNumber(deciSeconds, 1);
    timer += 100;
  sevseg.refreshDisplay(); // Must run repeatedly
/// END ///
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
Isaac96
The Arduino you have looks suspicious, but I am not sure.
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
Marmotjr
No No... we go into the future, get data, then return to the present.
robbieaoa
Hello!! I'm followning your project and I too am trying to build one of these. I was wondering if you think a nano would work? Not much room in that project box.
Stay tuned for some important announcements from our sponsor
HazardsMind
The Nano has more than enough pins to make it work.
My GitHub:
robbieaoa
HazardsMind
Current may still be an issue, as the digital pins only supply 40ma. So to power your display, I would recommend you use transistors and a good 5 volt power supply.
My GitHub:
robbieaoa
Just ordered a couple of nanos this morning. Having some trouble finding a 3 digit 7 segment display
