Topic: if no data do nothing (Read 4268 times) previous topic - next topic
PaulS
Quote
but why is it always getting stuck on last cammand recieved
What do your serial prints tell you is happening?
Can the motor driver actually go forward and turn at the same time?
merkzilla
with the motor shield im using it has lights that go on for each function so that made it much easier to test but yes all the commands wori just cant seem to tell it to do nothing or the motordriver.stop command i did notice that in serial monitor the RX side puts out the right camand number for data than goes back to 0 im assuming its supposed to anyway sense im subtract the same data number from the data. i try to set it to if theres no data to motordrive stop and thats supposed to stop all motors of course
this is what i have now with all four if statements
Code: [Select]
#include <Servo.h>
#include <MotorDriver.h>
Servo camera;
int data = 0;
const int rx_led = 42;
  //camera.attach(9);//camera control servo
  motordriver.init();
  motordriver.setSpeed(200, MOTORB);
  motordriver.setSpeed(200, MOTORA); // stering motor
  pinMode(rx_led, OUTPUT);
  digitalWrite(rx_led, LOW);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(6, INPUT);
  pinMode(7, INPUT);
  attachInterrupt(1, RF_VT, RISING);
  bool needToGoForward = false;
bool needToGoBackward = false;
bool needToTurnLeft = false;
bool needToTurnRight = false;
bool needToBreak = true;
  //direction
  if(data >= 8)
   needToTurnRight = true;
   needToBreak = false;
   data -= 8;
if(data >= 4)
   needToTurnLeft = true;
   data -= 4;
if(data >= 2)
   needToGoForward = true;
   data -= 2;
if(data >= 1)
   needToGoBackward = true;
   data -= 1;
if(needToGoForward)
   if(needToTurnLeft)
     motordriver.goForward();
     motordriver.goLeft();
   else if(needToTurnRight)
      motordriver.goRight();
else if(needToGoBackward)
   if(needToTurnLeft)
     motordriver.goBackward();
if(needToTurnLeft)
   if(needToGoForward)
if(needToTurnRight)
   if(needToGoForward)
  val = map(val, 0, 1023, 0, 180);
  camera.write();
  delay(50);
  Serial.print("data=");
  Serial.println(data, DEC);
void RF_VT() // interrupt service function
  data = (digitalRead(4) << 3) + (digitalRead(5) << 2) + (digitalRead(6) << 1) + (digitalRead(7) << 0);
PaulS
Code: [Select]
if(needToTurnLeft)
   if(needToGoForward)
No. No. No! You have already handled the need to go forward, while turning or not. You've already handled the need to go backwards, while turning or not.
merkzilla
sorry my bad i ment to chage this i was just trying things to see how the motor shield would react this is now
Code: [Select]
if(needToTurnLeft)
if(needToTurnRight)
Undermentioned
Im not really getting what you trying to do but if your problem is just stopping your motors when theres no data, none of your if statements will be true if there is no data but your motors will continue on the last command they got so you have to put a else statement right at the bottom of your main loop to tell them to stop .
M....
merkzilla
M....
you would think it would be so easy but i tried to set it as a esle statement and also if data == 0 to stop but it just doesnt
Undermentioned
If I was you I would just say:
Code: [Select]
Data = 0;
and not
Code: [Select]
Data -= 8// or what ever number you on;
And then does this function even work
Code: [Select]
motordriver.stop(); I dont know what library you are using.
Have you tested that function just with a simple sketch ?
merkzilla
yes the library has a example sketch that simply runs through all the camands and they work in the example
PaulS
Quote
Well, you should go back and read the entire thread. There is good reason for subtracting 8, 4, 2, and 1 rather than arbitrarily setting data (not Data - Data is a character on Star Trek - The Next Generation) to 0.
Quote
And, is it even being called? Serial.print() is better than guesswork 8 days a week.
Undermentioned
Ah ok I get it sorry also see theres two threads on this.
You got a long week Paul ;)
But Its true what Paul said, setup your else statement or == 0 statement and add a serial print and see if that line of code even gets executed.
If it does then you know theres something wrong with the stop function.
merkzilla
it has always worked for me i ont see why not in this scetch maybe if i set the bools back to orig settings t the end
if (needToBreak)
    motordriver.stop();
PaulS
Quote
Not necessary. They are local to loop(), so at the top, they will be recreated/reinitialized.
Start putting Serial.print() statements in the code. You need to print data at the start of loop(), where you use it, and you need to print the conditions that are true as you manipulate data.
Then, you need to print the conditions that are true as you use the booleans.
Are you sure that the 8, 4, 2, and 1 actions match what the sender is actually sending?
merkzilla
yes i monitored both serial monitors and both data matched as the buttons were pressed
merkzilla
update i put a serial print in each
and this is the data im getting back now
forward button
going forwarddata=0
backward button- puts out nothing
left button- puts out nothing
right button-puts out this series of data
ForLeftBackleftgoing backwardTurn leftdata=1
ForLeftBackleftgoing backwardTurn leftdata=0
going forwardgoing backwarddata=5
Code: [Select]
#include <Servo.h>
Servo camera;
int data = 0;
  motordriver.init();
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(6, INPUT);
  pinMode(7, INPUT);
  //data recieved for control
  if (data >= 8)
    data -= 8;
  if (data >= 4)
    data -= 4;
  if (data >= 2)
    data -= 2;
  if (data >= 1)
    data -= 1;
//forward commands
  if (needToGoForward)
    if (needToTurnLeft)
      Serial.print("ForLeft");
    else if (needToTurnRight)
    { Serial.print("ForRight");
      Serial.print("going forward");
//backward commands
    if (needToGoBackward)
      if (needToTurnLeft)
        Serial.print("Backleft");
        Serial.print("BackRight");
      Serial.print("going backward");
    if (needToTurnLeft)
      Serial.print("Turn left");
      Serial.print("Turn right");
    camera.write();
    delay(50);
PaulS
#29
May 31, 2015, 10:49 pm Last Edit: May 31, 2015, 10:51 pm by PaulS
You are trying to parse unknown data, and having problems. That is not surprising. So, the first issue to address is to stop trying to parse unknown data. In your case, that is incredibly simple. Simply print data (with identifier) at the top of loop().
Until you know that that value is correct, you are wasting your time (and ours).
Code: [Select]
NOTHING follows the {.
Code: [Select]
    if (needToTurnLeft)
This is STILL useless crap. You have ALREADY dealt with all possible cases. GET RID OF THIS SHIT!
These should be else if's, to handle the case where you are trying to turn without moving. Though that hardly makes sense to me.
