Topic: Arduino DRV8825 StepperMotor code (Read 30928 times) previous topic - next topic
MihaelR
Hello everyone!
I am having some trouble with the stepper motor. I use a stepper drive, called DRV8825, and this driver is connected like in the picture in the Attachment. For this setup i found an example code (see this page http://mchobby.be/wiki/index.php?title=DRV8825). When i start the stepper motor it vibrates only and won't turn circles.
What is the mistake i am making?
Tom Carpenter
Sounds like either the current limit is set too low for the motor, or more likely you have one of the wires mixed up.
If the wires are mixed up in such a way that a wire from one coil is swapped with a wire from the other, then you will see exactly this.
The other option is if you have a dodgy connection somewhere on your breadboard (no idea as you haven't shown a photo of your setup - nor a proper schematic -- fritzing is not a proper schematic!)
~Tom~
Robin2
Try this simple stepper code - it does work.
If it does not work for you then the problem lies elsewhere and we can try to help.
Provide a link to the datasheet for your stepper motor
Tell us what power supply you are using for the motor (volts and amps)
I presume you are following the wiring diagram on the Pololu DRV8825 web page
...R
Stepper Motor Basics
Two or three hours spent thinking and reading documentation solves most programming problems.
MihaelR
Hello everyone!
I am having some trouble controlling the stepper motor. For the setup I'm using the DRV8825. In the attachment you can see how I wired it.
I wired from above; orange, blue, red and yellow (see other attachment). When I used a code to drive this it wouldn't make circles. Instead it was making noises and holding its position.
Does anyone know what the problem is? It would make my day!
This was the code I was using:
// --- Commande d'un StepStick/Driver A4988 ----------------------
// DRV8825_Test.ino
// Commande d'un moteur pas-à-pas à l'aide d'un pilote DRV8825 avec
//     Arduino.
// Un projet www.mchobby.be (vente de kit et composant)
// Meurisse D. - Licence CC-SA-BY
// Un tutoriel http://wiki.mchobby.be/index.php?title=DRV8825
// Ou Acheter un StepStick DRV8825
//    http://shop.mchobby.be/product.php?id_product=454
#define pinEnable 13 // Activation du driver/pilote
#define pinStep    9 // Signal de PAS (avancement)
#define pinDir     8 // Direction
void setup(){
  Serial.println("Test DRV8825");
  pinMode( pinEnable, OUTPUT );
  pinMode( pinDir   , OUTPUT );
  pinMode( pinStep  , OUTPUT );
void loop(){
  int i = 0;
  digitalWrite( pinDir   , HIGH); // Direction avant
  digitalWrite( pinStep  , LOW);  // Initialisation de la broche step
  // Avance de 200 pas
  for( i=0; i<200; i++){
    Serial.println( i );
    digitalWrite( pinStep, HIGH );
    delay( 10 );
    digitalWrite( pinStep, LOW );
    delay( 10 );
  // Changer de direction
  digitalWrite( pinDir   , LOW); // Direction avant
  // Refaire 200 pas dans l'autre sens
    delay( 1 );
    delay( 1 );
  // Pas de step et pas d'ordre...
  //   l'axe du moteur est donc bloqué
  Serial.println("Axe bloqué + attendre 5 sec");
  delay( 5000 );
  // déblocage de l'axe moteur
  Serial.println("Deblocage axe");
  digitalWrite( pinEnable, HIGH ); // logique inversée
  // Fin et blocage du programme
  // Presser reset pour recommander
  Serial.println("Fin de programme");
  while( true );
johnwasser
Often that means that one of your coils is wired backwards.  Try swapping orange and blue.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
RayLivingston
There is no "backwards" for coils on a two-phase stepper motor.  if one coil is "reversed" the motor will simply turn the other direction.  If it's just making noise, and not moving, you're usually either not accelerating gradually enough, the step pulses have too much jitter, or the motor does not have enough torque to move the load.
Regards,
Ray L.
Tom Carpenter
Its not about reversing the *coil*, its about ensuring that the wires are not mixed up so one wire from one coil and one wire from the other coil are connected to the same H-bridge on the driver.
As per my earlier post, have you checked the current limit? Have you ensured the coils are wired up correctly?
~Tom~
Robin2
This quote is from Reply #3.
Did you read Reply #2 ?
...R
