Topic: How do I use a Makefile? (Read 7283 times) previous topic - next topic
ChromeBit
Hi there!
Someone has written code for a project I'm interested in and they have the following files:
main.c, another file with .c extension, a file with a .h extension and Makefile.
I've never made projects under than through the arduino program before uploading them to the chip... How would I go about using these?
keeper63
You may or may not need a make file:
http://playground.arduino.cc/Learning/CommandLine
That said - a google search on "arduino makefile" will pull up results - for instance:
http://hardwarefun.com/tutorials/compiling-arduino-sketches-using-makefile
http://www.itopen.it/arduino-1-0-development-with-a-makefile/
That said - you might want to post your code, because it sounds like what you might have is an AVR C program (perhaps for the ATMega328 - but who knows?) - and not an Arduino program necessarily. Or - you may have the post pre-processed version of the code (but prior to compilation to the .hex file).
Either way - being able to take a look at all of the code -and- the makefile would be very helpful.
Likely - you'll just place it all in a single directory, perhaps alter a line or two in the makefile (?), then type "make" or "make all" or "make install" or ...? That would depend on the makefile and how it is set up - but without seeing it, I don't know what the proper "make" command would be.
This also assumes you are running Linux or OSX (Mac) or some other sane *nix - otherwise, IIRC, you have to set up a "unix-like" environment under Windows to use make (?) - cygwin or similar...I'm not a windows guy so without looking it up and studying it, I'm not sure what the process would be on that platform, but it may take a few more steps (or it may not).
So - post the code first - and let us know what platform you will be compiling this on (Windows, Mac, Linux, something else?)...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
keeper63
Eh - regarding windows - found this (google "windows arduino makefile"):
http://forum.arduino.cc/index.php?topic=37813.0
ChromeBit
Thanks for your help so far,
This is a link to the files:
https://github.com/ComputerNerd/ov7670-no-ram-arduino-uno
keeper63
Well - that's not an arduino project.
It's meant to be compiled using avr-gcc and uploaded using avrdude - which you'll have with the Arduino IDE installed. Its targeted at the ATMega328 (ie - an Arduino Uno), and the Arduino as the programmer (ie - over USB).
So, once you have things set up on your system (you still didn't mention what you are using) - you should be able to type (in the directory where the makefile is) "make" or "make all" - then "make install" to get it over to the Arduino.
The Arduino needs to be plugged in to the USB - and the port it is set to is in the makefile - currently set to "/dev/ttyACM0" - you'll need to alter that line (on line 120) to point to the proper serial port.
Note that all of this is for *nix - I am not sure what you'll need to do under Windows. But the process should be somewhat similar.
