Topic: Arduino color game (Bomber) using VGA library (Read 38924 times) previous topic - next topic
rob_cai
Jun 09, 2015, 12:55 am Last Edit: Jul 01, 2015, 02:28 pm by rob_cai
Hello to all,
thanks to the VGAx library done by Smaffer, based on the previous work done by Nick Gammon, I have done a little color game for an Arduino Uno working for a VGA monitor. See for details here:
The target was to use an Arduino Uno board without special shields and supporting IC.
the fundamental components are a button, a potenziometer, few resistors and DSUB15 connector.
For the VGA library, the DSUB15 connections, and for the color choice, please refer to smaffer post:
The potenziometer should be connected to analogue pin 2 (A2), the button to analogue pin 1 (A1) and the buzzer to A0.
The code is attached here.
Enjoy!
NB an update of the game (version 02) is available in this post at #6
zoomx
In the sketch I found this
Code: [Select]
#define BUTTON_PIN 0  //NB: by default, this pin (A0) is used in the VGAx library to generate the audio.
//#define BUTTON_PIN 2
#define WHEEL_PIN 1
It seems that button pin is on A0. Why you used an analogue pin?
Anyway I agree Nick Gammon: Very impressive!
rob_cai
Good question! And thank you for the positive comment!
This is an "inheritance" of a previous code, i.e. Arduino Bomber B&W with TVout library that I did before the VGA version (see here).
I had problem in the past with the digitalRead command (sorry, I forgot the details).
By the way, later on I trasform the "analog" read of the button in a 0 - 1 form with the following part:
Code: [Select]
void processInputs() {
  wheelPosition = analogRead(WHEEL_PIN);
  buttonStatus = (analogRead(BUTTON_PIN) > 512);
and thus buttonStatus became either 1 or 0.
This is an inelegant solution but it works...
zoomx
I don't understand the use of the analog pin in this way since you can use the analog pin as digital as written here
http://www.arduino.cc/en/Tutorial/AnalogInputPins
Quote
Pin mapping
The analog pins can be used identically to the digital pins, using the aliases A0 (for analog input 0), A1, etc. For example, the code would look like this to set analog pin 0 to an output, and to set it HIGH:
pinMode(A0, OUTPUT);
digitalWrite(A0, HIGH);
[/pre]
Anyway this is a sketch that I must try! :)
rob_cai
#4
Jun 09, 2015, 10:49 pm Last Edit: Jun 09, 2015, 10:51 pm by rob_cai
dear zoomx,
I applied the correction you suggest. The behaviour is the same but the code is more understandable.
Now the code has:
Code: [Select]
#define BUTTON_PIN A0
//#define BUTTON_PIN A2
  buttonStatus = digitalRead(BUTTON_PIN) ;
instead of:
Code: [Select]
I understand a bit more now!
I am glad you want to try it. Let me know!
smaffer
Good work Rob Cai!
Your game is the first that use VGAX! In the next commit i will add your game in the github notes.
Thank you!
rob_cai
#6
Jun 14, 2015, 10:43 pm Last Edit: Jan 06, 2016, 12:45 pm by rob_cai
A second version of "Arduino Bomber" is ready!
It uses the recent "VGAXUtils.h" written by Smaffer, to draw lines, circles, rectangles, and so on (see his post for details).
The code has needed deep modifications to be compatible with these functions, but the screen is now drawn roughly ten times faster and the game became more smooth and precise.
As said before: enjoy!
P.S. the second file (bomber_alpha.ino) is the "old" version for TVout libraries
rob_cai
#8
Jun 20, 2015, 10:40 pm Last Edit: Aug 23, 2015, 11:34 pm by rob_cai
I have done a "new" game:
Pong with colors and sound, running for a VGA monitor.
Link to the video here:
As for "Bomber", this game does not need a special shield or support chips, but just few resistors, a DSUB15 connector, a pair of potenziometers and a buttons.
Since I am using only one potenziometer and button, the two paddles move in parallel. Anyway, the code is ready for the "second player".
The code is at the bottom.
Enjoy!
NB second version at #13
aldolo
complimenti. sicuramente cercherò di riprodurlo.
rob_cai
Grazie, fammi sapere come va. Se hai domande, chiedi pure!
rob_cai
Hi Smaffer,
it is really unbelievable what you have done with a bare Arduino, without the help of any other supporting chip!
When you will publish the first release of the game, I will be one of the first to download and try it.
Cheers.
rob_cai
#12
Aug 23, 2015, 11:20 pm Last Edit: Sep 14, 2015, 12:05 pm by rob_cai
Pong VGA with colors and for two players is ready!
The code has been updated for the latest VGAx library by Smaffer (August 2015) and overall optimized for two separated players. Many bugs have been fixed, expecially involving the restart of a new match.
In this video, I show the whole setup placed in two rock solid wood box. A bigger one for the Arduino board, the DSUB15 connector and the first player button and wheel; the second player paddle, containing only his button and wheel, is connected to the main one with a recycled USB cable and socket. In this way the main box can be used for my previous single player game (Arduino Bomber).
Enjoy!
mikelemon
odometer
As for "Arduino Bomber": I noticed this line in the code:
Code: [Select]
  Vaereo = 0.1 + random(20)/100;
Won't that always give you 0.1 ? (because random(20)/100 will always give you 0)
