Topic: Headlight control (Read 5488 times) previous topic - next topic
jcallen
#90
Jun 16, 2015, 06:24 am Last Edit: Jun 16, 2015, 05:07 pm by jcallen
Would this work?
Run the wires from the dimmer switch to inverters flipping the logic states, switch the HI wire to the LO relay and vice versa, put a power diode between the relays with cathode toward LO.
When switched to high point A will be HI making point C LO turning off LO relay.
Since point B is LO point D will be HI turning HI relay on and routing voltage thru diode making LO relay stay on.
When switched to low, point A would go LO instantly, making point C HI.
point B would go HI making point D LO turning HI relay off.
NO time delay because we are switching when a circuit breaks instead of waiting for one to make.
Points A & B would be pulled low with resistors.
Ogmudbones
Well thanks to @jcallen the code works and the device as a whole works.
Ogmudbones
I spoke to soon...i have no idea whats wrong with this thing
