Topic: Add DATE and TIME to your SD CARD Files. (Read 3075 times) previous topic - next topic
CosmickGold
Jun 18, 2015, 11:05 pm Last Edit: Jun 18, 2015, 11:29 pm by CosmickGold
I needed to add the normal Date/Time stamp to the SD CARD files my project creates, to ensure my final product will impress customers as being professional, rather than seeming "hobbyist".  But the forum topics I found for the purpose require more libraries which in turn require initialization statements; all of which consumes more of the Uno's limited memory. In addition, comments on those topics revealed those libraries only work for some hardware/software versions, leaving more questions than answers.
So....  using some code provided by Nick Gammon and some by fat16lib, I created a sketch that only needs the SD.h library already running your SD Card.  I hand-entered a "fake" time/date, so you can easily test the sketch.  But to make it useful, you'll need to add code to retrieve the real time/date from whatever hardware source you are using. In my project, I'm using this realtime clock.
And here's my test sketch:
Code: [Select]
#include <SD.h>
File file;
const uint8_t CS = 10; // SD chip select
    // YOUR SKETCH SHOULD UPDATE THESE SIX VALUSE
    // EACH TIME BEFORE CREATING YOUR SD CARD FILE
unsigned int year = 2015;
byte month = 6;
byte day = 18;
byte hour = 7;
byte minute = 8;
byte second = 9;
void dateTime(uint16_t* date, uint16_t* time)
  *date = FAT_DATE(year, month, day);
  *time = FAT_TIME(hour, minute, second);
      // THIS LINE SETS YOUR SKETCH TO SAVE YOUR
      // TIME AND DATE INTO ANY FILE YOU CREATE.
  SdFile::dateTimeCallback(dateTime);
  if (!SD.begin(CS))
    Serial.println("SD.begin failed");
    while(1);
  file = SD.open("TEST_IT.TXT", FILE_WRITE);
  file.close();
  Serial.println("Done");
void loop() {}
gjt211
Thanks, that worked perfectly for me using the standard Arduino SD library.
fatfenders
Best and simplest example of this code I have viewed! Works great.
