Topic: code of ESC (Read 2290 times) previous topic - next topic
Yahia_Elsaeed
the code :
#include <Servo.h>
Servo myservo;
void arm(){
 setSpeed(0);
 delay(1000); //delay 1 second,  some speed controllers may need longer
void setSpeed(int speed){
 int angle = map(speed, 0, 100, 0, 180);
 myservo.write(angle);
 myservo.attach(9);
 arm();
 int speed;
 for(speed = 0; speed <= 100; speed += 5) {
   setSpeed(speed);
 // sweep back down to 0 speed.
 for(speed = 95; speed > 0; speed -= 5) {
   setSpeed(speed);
the contact way
http://83.56.32.125/images/smesquema.jpg
all work ok with me .. but i want know what is must to edit from this code to can remove the pot ?
JimboZA
There's nothing in that code that has anything to do with the pot in the first place.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Yahia_Elsaeed
u mean if remove pot it will work without any edit in code ?
JimboZA
Well what line in that code do you think relate to a pot?
Yahia_Elsaeed
Isaac96
There isn't even a line that relates to a input.
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
Yahia_Elsaeed
so can i use this connection now
http://api.ning.com/files/QYxylXSaas588I6jwxcoAJR8lBXneWApDBFHGCoOMg7Ge975QGTPeT0Qinw4ffnFDRoWYf7TcktkQRYX--0YwbQT05HgK*zp/arduino_esc_lucaszanela_com.png
without any modified in code ?
JimboZA
idk
You should work through the code line by line to answer my question. Answer is "none", as Isaac96 points out:
So that code will not care if there's a pot attached or not.
MarkT
Well you've removed the 5V supply to the Arduino from the ESC's BEC.
You'll have to have USB plugged in therefore.
Actually I'd never trust the BEC in a cheap ESC to power anything in the first place, I've seen ESC's
explode and die spectacularly...
Yahia_Elsaeed
i use EMAX esc  and it has high quality
Isaac96
I use Turnigy Plush.  :) But I really killed one of my 3S LiPo batteries (it seems to have been crumpled) and the voltage dropped to 6V. I was wondering why the receiver wasn't turning on.
