Topic: WAV Trigger integration... (Read 425 times) previous topic - next topic
moses1592
Sorry if this topic is miscategorized. I want to use a WAV Trigger with Arduino in such a way that, when one of the I/O pins is triggered for, say 250ms, the WAV Trigger will play that particular track one time and stop. Normally the Trigger will play that particular track (and repeat it if needed) as long as it's input trigger is HIGH. What I need is that, once its momentarily triggered it'll simply play that track through one time then stop.
How do I do this? Is it through coding or a particular wiring setup?
Thanks!
UKHeliBob
Ok, I give up.  What is a WAV Trigger ?
moses1592
Programmable sound board. Can play WAV files off of micro SD card, has trigger pins for each track.
UKHeliBob
How will the Arduino know when to stop the track playing ?  Can the mysterious WAV Trigger device signal that a track has finished ?
