Topic: xbee wireless communication using joystick  (Read 2210 times) previous topic - next topic
aman25
Jun 24, 2015, 08:38 am Last Edit: Jul 11, 2015, 01:48 pm by aman25
code at receiver side .
#include<EasyTransfer.h>
//#include<Wire.h>
int a1=2;
int a2=3;
int b1=4;
int b2=5;
int jack=6;
int m;
int n;
EasyTransfer lt;
typedef struct RECEIVE_DATA_STRUCTURE
int x;
int y;
int z;
RECEIVE_DATA_STRUCTURE aman;
//#define  I2C_SLAVE_ADDRESS 9
void setup(){
//Wire.begin(I2C_SLAVE_ADDRESS);
lt.begin(details(aman),&Serial);
//Wire.onreceieve
pinMode(a1,OUTPUT);
pinMode(a2,OUTPUT);
pinMode(b1, OUTPUT);
pinMode(b2,OUTPUT);
pinMode(jack,OUTPUT);
if(lt.receiveData())
m=map(m,0,1023,-1,1);
n=map(n,0,1023,-1,1);
if(m==0 && n==0)
digitalWrite(a1,LOW);
digitalWrite(a2,LOW);
digitalWrite(b1,LOW);
digitalWrite(b2,LOW);
else if(m==0 && n==1)
digitalWrite(a1,HIGH);
digitalWrite(a2,HIGH);
else if(m==0 && n==-1)
digitalWrite(b1,HIGH);
digitalWrite(b2,HIGH);
else if(m==1 && n==0)
else if(m==-1 && n==0)
this is my arduino code for receiver side and i am using xbee for wireless communication , but the problem is i am not able to get the output  on other side . plz help me .
code at transmitter side
int vx=A0;
int vy=A1;
int cam=8;
EasyTransfer lt;
struct SEND_DATA_STRUCTURE
int x;
int y;
int z;
SEND_DATA_STRUCTURE aman;
pinMode(cam,INPUT);
aman.x=analogRead(vx);
aman.y=analogRead(vy);
aman.z=digitalRead(cam);
lt.sendData();
Isaac96
Try something like the SoftwareSerial examples first to make sure the XBee's are working.
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
shubhsa
yes i have tested my xbee and its  working properly ,  the problem i am facing is of my code can you tell me that my code is right .
zoomkat
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
zoomkat
aman25
thanxx for the help sir , but i am working with dc motors, joystick and xbees . and the link you have given me is of servo and pot .
sir it would be great help if  you can help with code which i have posted earlier in this thread .
Isaac96
Joysticks are just pots. And it is easy to convert servo commands to DC motor commands.
aman25
sir can you tell me the mode in which xbee should be configured , i mean which xbee as coordinator and which to router.
Isaac96
Transparent is great for XBees. They just take data and send it.
aman25
the problem i am facing is that the din light of one xbee is continuously blinking but in other xbee only rssi and power lights   are on . i dont know how to overcome this problem . plz help me out .
Isaac96
Have you used X-CTU to configure your XBees?
aman25
yes sir i have used x-ctu to configure xbee but the xbees are not transmitting the data . plz help sir
Isaac96
#12
Jul 04, 2015, 04:48 pm Last Edit: Jul 04, 2015, 04:51 pm by Isaac96
Do you have the right baud rate?
EDIT See http://cpham.perso.univ-pau.fr/WSN/XBee.html
andyibanez
Better to use #softwareserial
Use 10 for Rx and 11 for Tx
U must try communicate between xbee with 2 xbee explorer first
Use software serial library,
Myserial.println(data);
aman25
sir both the xbees are communicating in there terminal but when any signal is given from joystick they are transmitting data . plz help sir
