Hi!
I am in the process of replacing the control circuitry on a piece of test equipment which releases a large weight (over 500KG) down a slope and collides it with a solid object. Obviously this is a potentially dangerous situation and as such there are a number of safety measures in place which need to remain once the system is run by an Arduino. I have put together the attached schematic and would like feedback on it.
The safety switch is attached to a gate which must be closed in order for the rig to "fire" (ie release the load), a red and green LED display the state of this gate, in addition to this the Arduino must have "armed" the rig by pulling one of it's pins high (shown as "Arduino Out" on the schematic), an additional red and green LED shows whether the rig is ready to be fired, assuming it is the fire button will then release the load down the slope. The load is released by pneumatic rams controlled by a 12V solenoid (shown on the schematic as "LOAD").
If anyone could point out any obvious errors and provide general feedback on the design of the circuit it would be much appreciated, in additional any pointers on working out the specs required for the components would help (I need to work out the resistance of R1, R2, R3, R4, R5 and R6, the transistor spec for Q1, Q2 and Q3, what diodes to use for D1 and D2 and what sort of MOSFET would be appropriate to drive the solenoid).
Thanks in advance.
