Topic: Programmer not responding (Read 17014 times) previous topic - next topic
ameychaware
I recently bought a new computer, so I had to install Arduino again. As a start, to test if everything properly working or not, I was trying to program my UNO with Blink. But I am getting following Output:Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Uno"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc1
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
  enabled in File > Preferences.
I am using Win8.1 64bit with Arduino Uno R3
Cheers!
Amey
prashant2608
I am also having same error, so if you have found the solution then please inform ..
Thanks
pbombhi
I'm having the exact same problem. I tried rebooting my laptop and reinstalling the program. Hasn't fixed it yet.
SantinoPrice
 Could you all try the loop-back test, linked can be found at the top of this sub-forum, and let me know the outcome.
Need help troubleshooting problems with your Arduino (Uno, Mega or Pro-mini) have a look at my book on the kindle store.
 Arduino Troubleshooting
RobbertRitmeester
What am I overlooking? Cannot find the link to the loop-back test at the top...
AWOL
#5
Jul 09, 2015, 01:35 pm Last Edit: Jul 09, 2015, 01:35 pm by AWOL
You mean the one labelled Loop-back test instructions?
RobbertRitmeester
RobbertRitmeester
My Duemilanove passed the loop back test (all text was exactly returned).
Trying to upload Blink or BareMinimum still fails (programmer is not responding)
SantinoPrice
@RobbertRitmeester
Can you describe the behaviour of your "L" led when the board is just powered up or reset?
Passing the loop-back test and still gettingnthat error usually indicates a missing/corrupt bootloader or a damaged chip. Observing the led mentioned above is normally a good indicater of whether or not your bootloader is in fact corrupted.
RichiePiet
Hi. Newbie here and not sure if its proper to post in this thread. If not can you point me in the right direction?
I get a similar error...
I can compile and upload any example sketch without an error but when I try to upload GRBL I get this error. I've tried re- downloading GRBL and different versions of Arduino. I am running windows 7 and an old Uno. I'm running Arduino 1.6.1 now.
I couldn't find a topic for this problem. Should I create a new thread?
Code: [Select]
Sketch uses 28,790 bytes (89%) of program storage space. Maximum is 32,256 bytes.
Global variables use 1,485 bytes (72%) of dynamic memory, leaving 563 bytes for local variables. Maximum is 2,048 bytes.
RichiePiet
Hi. I borrowed a friends Uno R3 and all is working now.
All I did was load the drivers for the Uno R3, because device manager reported no driver loaded, opened Arduino IDE and uploaded the same GRBL file that was not working on my Uno.
I think the bootloader and/or device drivers may be out of date. I tried to burn a new bootloader. I could not burn it though. I think this might be a Avrdude and Avr studio driver conflict.
SantinoPrice
To burn the bootloader you need to use some sort of ISP device. You can find guides online on how to use another Arduino (such as your friend's Uno) as an ISP device with the help of the ArduinoISP sketch.
devanshkhandekar
i am having the same problem
Arduino: 1.6.5 (Windows 7), Board: "Arduino Uno"
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x54
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x04
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x10
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x54
RobbertRitmeester
I did the loop back test: passed. I monitored the L led while powering up the board: nothing. No blinks.
Is the board broken?
@santinoPrice: thanks for your replies!
dmjlambert
My recommended steps if you pass the loop back test:
Make sure the correct port is selected in Tools, Port
Try setting Tools, Board to Arduino Duemilanove or Diecimila
  On the menu go to Sketch, Upload
Try setting Tools, Board to Arduino Uno
  Try upload again
In case your automatic reset is not working, you can also try pressing reset when uploading using the above steps, and release it when the IDE says "uploading."
Go through the troubleshooting guide at https://www.arduino.cc/en/Guide/Troubleshooting
Still failing above steps I would recommend using another Arduino as an ISP programmer, or use an ISP programmer device,  and burn a fresh bootloader on your Duemilanove.      https://www.arduino.cc/en/Tutorial/ArduinoISP
