Topic: Reset over BLE and upload sketch (Read 1 time) previous topic - next topic
4ntoine
Jul 04, 2015, 04:44 pm Last Edit: Jul 04, 2015, 04:47 pm by 4ntoine
I'm working on wireless uploader for Arduino from iOS devices. I'm using HM-10 BLE module which seems to work ok. PIO 2 is used as DTR for resetting (see
Quote
A [0x41] T [0x54] + [0x2B] P [0x50] I [0x49] O [0x4F] 2 [0x32] 1 [0x31]
and
Quote
A [0x41] T [0x54] + [0x2B] P [0x50] I [0x49] O [0x4F] 2 [0x32] 0 [0x30]
below)- using 0.1uF capacitor and 10K resistor wired to MCU reset pin)(http://electronics.stackexchange.com/questions/61537/what-is-the-cap-for-in-arduino-reset-circuit). Reset seems to be done correctly as i'm getting `ready` output (in 'setup()' body in uploaded sketch).
For some reason i'm getting `0x14 0x10` for `0x30 0x20` request (to ping bootloader) but not getting response for `A [0x41] . [0x81]   [0x20]` within almost 1 second.
Uploading over BLE:
Code: [Select]
    2015-07-04 19:24:10.955 xctest[54864:5122867] [TRACE  ] [OUT]: Send: A [0x41] T [0x54] + [0x2B] P [0x50] I [0x49] O [0x4F] 2 [0x32] 1 [0x31]
    2015-07-04 19:24:10.955 xctest[54864:5122867] [TRACE  ] [OUT]: BLE sending bytes range from 0 length 8
    2015-07-04 19:24:11.106 xctest[54864:5122867] [DEBUG  ] [OUT]: Sending 8 bytes
    2015-07-04 19:24:11.106 xctest[54864:5122867] [TRACE  ] [OUT]: Send: A [0x41] T [0x54] + [0x2B] P [0x50] I [0x49] O [0x4F] 2 [0x32] 0 [0x30]
    2015-07-04 19:24:11.106 xctest[54864:5122867] [TRACE  ] [OUT]: BLE sending bytes range from 0 length 8
    2015-07-04 19:24:11.148 xctest[54864:5122867] [DEBUG  ] [   ]: Draining for 230 ms ...
    2015-07-04 19:24:11.148 xctest[54864:5122867] [TRACE  ] [IN ]: Start reading
    2015-07-04 19:24:11.323 xctest[54864:5122903] [TRACE  ] [IN ]: Rx value received 9 bytes: O [0x4F] K [0x4B] + [0x2B] P [0x50] I [0x49] O [0x4F] 2 [0x32] : [0x3A] 1 [0x31]
    2015-07-04 19:24:11.323 xctest[54864:5122903] [TRACE  ] [IN ]: Rx value received 9 bytes: O [0x4F] K [0x4B] + [0x2B] P [0x50] I [0x49] O [0x4F] 2 [0x32] : [0x3A] 0 [0x30]
    2015-07-04 19:24:11.381 xctest[54864:5122867] [TRACE  ] [IN ]: Finish reading
    2015-07-04 19:24:11.381 xctest[54864:5122867] [TRACE  ] [IN ]: Ble clear buffer
    2015-07-04 19:24:11.381 xctest[54864:5122867] [DEBUG  ] [IN ]: Drained 18 bytes
    2015-07-04 19:24:11.381 xctest[54864:5122867] [DEBUG  ] [OUT]: Sending 2 bytes
    2015-07-04 19:24:11.381 xctest[54864:5122867] [TRACE  ] [OUT]: Send: 0 [0x30]   [0x20]
    2015-07-04 19:24:11.382 xctest[54864:5122867] [TRACE  ] [OUT]: BLE sending bytes range from 0 length 2
    2015-07-04 19:24:11.382 xctest[54864:5122867] [DEBUG  ] [IN ]: Reading 1 bytes ...
    2015-07-04 19:24:11.382 xctest[54864:5122867] [TRACE  ] [IN ]: Start reading
    2015-07-04 19:24:11.746 xctest[54864:5122914] [TRACE  ] [IN ]: Rx value received 1 bytes: . [0x00]
    2015-07-04 19:24:11.747 xctest[54864:5122914] [TRACE  ] [IN ]: Ignoring single 0x00 char
    2015-07-04 19:24:11.747 xctest[54864:5122914] [TRACE  ] [IN ]: Rx value received 2 bytes: . [0x14] . [0x10]
    2015-07-04 19:24:11.748 xctest[54864:5122867] [TRACE  ] [IN ]: Finish reading
    2015-07-04 19:24:11.748 xctest[54864:5122867] [TRACE  ] [IN ]: Receive: . [0x14]
    2015-07-04 19:24:11.749 xctest[54864:5122867] [DEBUG  ] [IN ]: Read 1 bytes, actually received 2 bytes
    2015-07-04 19:24:11.749 xctest[54864:5122867] [TRACE  ] [IN ]: 1 bytes in incoming buffer remaining for next receive
    2015-07-04 19:24:11.749 xctest[54864:5122867] [DEBUG  ] [IN ]: Reading 1 bytes ...
    2015-07-04 19:24:11.750 xctest[54864:5122867] [TRACE  ] [IN ]: Having current receive buffer: . [0x10]
    2015-07-04 19:24:11.750 xctest[54864:5122867] [TRACE  ] [IN ]: Start reading
    2015-07-04 19:24:11.750 xctest[54864:5122867] [TRACE  ] [IN ]: Finish reading
    2015-07-04 19:24:11.751 xctest[54864:5122867] [TRACE  ] [IN ]: Receive: . [0x10]
    2015-07-04 19:24:11.751 xctest[54864:5122867] [DEBUG  ] [IN ]: Read 1 bytes, actually received 1 bytes
    2015-07-04 19:24:11.751 xctest[54864:5122867] [TRACE  ] [IN ]: Ble clear buffer
    2015-07-04 19:24:11.752 xctest[54864:5122867] [DEBUG  ] [OUT]: Sending 3 bytes
    2015-07-04 19:24:11.752 xctest[54864:5122867] [TRACE  ] [OUT]: Send: A [0x41] . [0x81]   [0x20]
    2015-07-04 19:24:11.752 xctest[54864:5122867] [TRACE  ] [OUT]: BLE sending bytes range from 0 length 3
    2015-07-04 19:24:11.752 xctest[54864:5122867] [DEBUG  ] [IN ]: Reading 1 bytes ...
    2015-07-04 19:24:11.753 xctest[54864:5122867] [TRACE  ] [IN ]: Start reading
    2015-07-04 19:24:11.821 xctest[54864:5122914] [TRACE  ] [IN ]: Rx value received 1 bytes: . [0x00]
    2015-07-04 19:24:11.821 xctest[54864:5122914] [TRACE  ] [IN ]: Ignoring single 0x00 char
    2015-07-04 19:24:12.721 xctest[54864:5122903] [TRACE  ] [IN ]: Rx value received 5 bytes: r [0x72] e [0x65] a [0x61] d [0x64] y [0x79]
    2015-07-04 19:24:12.722 xctest[54864:5122867] [TRACE  ] [IN ]: Finish reading
    2015-07-04 19:24:12.722 xctest[54864:5122867] [TRACE  ] [IN ]: Receive: r [0x72]
    2015-07-04 19:24:12.723 xctest[54864:5122867] [DEBUG  ] [IN ]: Read 1 bytes, actually received 5 bytes
    2015-07-04 19:24:12.723 xctest[54864:5122867] [TRACE  ] [IN ]: 4 bytes in incoming buffer remaining for next receive
    2015-07-04 19:24:12.723 xctest[54864:5122867] [ERROR  ] [   ]: STK500:getParameter: protocol error #1, expected [0x14], received [0x72]
4ntoine
#1
Jul 04, 2015, 04:45 pm Last Edit: Jul 04, 2015, 04:45 pm by 4ntoine
When uploading over usb it's ok:
Code: [Select]
2015-06-29 16:34:10.829 xctest[36585:3703900] [TRACE  ] [   ]: DTR/RTS supported by Serial, resetting
    2015-06-29 16:34:11.140 xctest[36585:3703900] [DEBUG  ] [IN ]: Draining ...
    2015-06-29 16:34:11.392 xctest[36585:3703900] [DEBUG  ] [IN ]: Drain done
    2015-06-29 16:34:11.392 xctest[36585:3703900] [DEBUG  ] [OUT]: Sending 2 bytes
    2015-06-29 16:34:11.392 xctest[36585:3703900] [TRACE  ] [OUT]: Send: 0 [0x30]   [0x20]
    2015-06-29 16:34:11.393 xctest[36585:3703900] [DEBUG  ] [IN ]: Receiving 1 bytes
    2015-06-29 16:34:11.531 xctest[36585:3703900] [TRACE  ] [IN ]: Received: . [0x14]
    2015-06-29 16:34:11.531 xctest[36585:3703900] [DEBUG  ] [IN ]: Receiving 1 bytes
    2015-06-29 16:34:11.532 xctest[36585:3703900] [TRACE  ] [IN ]: Received: . [0x10]
    2015-06-29 16:34:11.532 xctest[36585:3703900] [DEBUG  ] [OUT]: Sending 3 bytes
    2015-06-29 16:34:11.532 xctest[36585:3703900] [TRACE  ] [OUT]: Send: A [0x41] . [0x81]   [0x20]
    2015-06-29 16:34:11.533 xctest[36585:3703900] [DEBUG  ] [IN ]: Receiving 1 bytes
    2015-06-29 16:34:11.535 xctest[36585:3703900] [TRACE  ] [IN ]: Received: . [0x14]
    2015-06-29 16:34:11.536 xctest[36585:3703900] [DEBUG  ] [IN ]: Receiving 1 bytes
    2015-06-29 16:34:11.536 xctest[36585:3703900] [TRACE  ] [IN ]: Received: . [0x04]
    2015-06-29 16:34:11.536 xctest[36585:3703900] [TRACE  ] [IN ]: Received: . [0x10]
    2015-06-29 16:34:11.537 xctest[36585:3703900] [DEBUG  ] [OUT]: Sending 3 bytes
    2015-06-29 16:34:11.537 xctest[36585:3703900] [TRACE  ] [OUT]: Send: A [0x41] . [0x82]   [0x20]
    2015-06-29 16:34:11.537 xctest[36585:3703900] [DEBUG  ] [IN ]: Receiving 1 bytes
    2015-06-29 16:34:11.540 xctest[36585:3703900] [TRACE  ] [IN ]: Received: . [0x14]
So when uploading over USB DTR/RTS and similar schematic is used.
I think the problem is in resetting approach - wiring to reset does not work when trying to upload. Am i right? Is it bootloader issue?
PS. Arduino sketch uploaded:
Code: [Select]
      Serial.print("ready");
      pinMode(13, OUTPUT);
      digitalWrite(13, LOW);
4ntoine
#2
Jul 04, 2015, 04:53 pm Last Edit: Jul 04, 2015, 04:53 pm by 4ntoine
HM-10 is in mode 1 which allows to send 'AT' commands after pairing (see it performs PIO set to 1 and then to 0 to reset MCU). I'm not sure is HM-10 does transmit
Quote
to the MCU actually
4ntoine
#3
Jul 04, 2015, 04:56 pm Last Edit: Jul 04, 2015, 04:56 pm by 4ntoine
if i send
Quote
0x30 0x20
twice just to check connection with bootloader after reset it responds twice as expected.
Code: [Select]
2015-07-04 19:55:19.302 xctest[54929:5148304] [TRACE  ] [IN ]: Start reading
2015-07-04 19:55:19.486 xctest[54929:5148356] [TRACE  ] [IN ]: Rx value received 9 bytes: O [0x4F] K [0x4B] + [0x2B] P [0x50] I [0x49] O [0x4F] 2 [0x32] : [0x3A] 1 [0x31]
2015-07-04 19:55:19.524 xctest[54929:5148356] [TRACE  ] [IN ]: Rx value received 9 bytes: O [0x4F] K [0x4B] + [0x2B] P [0x50] I [0x49] O [0x4F] 2 [0x32] : [0x3A] 0 [0x30]
2015-07-04 19:55:19.536 xctest[54929:5148304] [TRACE  ] [IN ]: Finish reading
2015-07-04 19:55:19.537 xctest[54929:5148304] [TRACE  ] [IN ]: Ble clear buffer
2015-07-04 19:55:19.537 xctest[54929:5148304] [DEBUG  ] [IN ]: Drained 18 bytes
2015-07-04 19:55:19.537 xctest[54929:5148304] [DEBUG  ] [OUT]: Sending 2 bytes
2015-07-04 19:55:19.538 xctest[54929:5148304] [TRACE  ] [OUT]: Send: 0 [0x30]   [0x20]  // check #1
2015-07-04 19:55:19.538 xctest[54929:5148304] [TRACE  ] [OUT]: BLE sending bytes range from 0 length 2
2015-07-04 19:55:19.538 xctest[54929:5148304] [DEBUG  ] [IN ]: Reading 1 bytes ...
2015-07-04 19:55:19.539 xctest[54929:5148304] [TRACE  ] [IN ]: Start reading
2015-07-04 19:55:19.599 xctest[54929:5148343] [TRACE  ] [IN ]: Rx value received 1 bytes: . [0x00]
2015-07-04 19:55:19.599 xctest[54929:5148343] [TRACE  ] [IN ]: Ignoring single 0x00 char
2015-07-04 19:55:19.974 xctest[54929:5148356] [TRACE  ] [IN ]: Rx value received 2 bytes: . [0x14] . [0x10]
2015-07-04 19:55:19.974 xctest[54929:5148304] [TRACE  ] [IN ]: Finish reading
2015-07-04 19:55:19.975 xctest[54929:5148304] [TRACE  ] [IN ]: Receive: . [0x14]
2015-07-04 19:55:19.975 xctest[54929:5148304] [DEBUG  ] [IN ]: Read 1 bytes, actually received 2 bytes
2015-07-04 19:55:19.975 xctest[54929:5148304] [TRACE  ] [IN ]: 1 bytes in incoming buffer remaining for next receive
2015-07-04 19:55:19.975 xctest[54929:5148304] [DEBUG  ] [IN ]: Reading 1 bytes ...
2015-07-04 19:55:19.976 xctest[54929:5148304] [TRACE  ] [IN ]: Having current receive buffer: . [0x10]
2015-07-04 19:55:19.976 xctest[54929:5148304] [TRACE  ] [IN ]: Start reading
2015-07-04 19:55:19.976 xctest[54929:5148304] [TRACE  ] [IN ]: Finish reading
2015-07-04 19:55:19.977 xctest[54929:5148304] [TRACE  ] [IN ]: Receive: . [0x10]
2015-07-04 19:55:19.977 xctest[54929:5148304] [DEBUG  ] [IN ]: Read 1 bytes, actually received 1 bytes
2015-07-04 19:55:19.977 xctest[54929:5148304] [TRACE  ] [IN ]: Ble clear buffer
2015-07-04 19:55:19.978 xctest[54929:5148304] [DEBUG  ] [OUT]: Sending 2 bytes
2015-07-04 19:55:19.978 xctest[54929:5148304] [TRACE  ] [OUT]: Send: 0 [0x30]   [0x20] // check #2
2015-07-04 19:55:19.978 xctest[54929:5148304] [TRACE  ] [OUT]: BLE sending bytes range from 0 length 2
2015-07-04 19:55:19.979 xctest[54929:5148304] [DEBUG  ] [IN ]: Reading 1 bytes ...
2015-07-04 19:55:19.979 xctest[54929:5148304] [TRACE  ] [IN ]: Start reading
2015-07-04 19:55:20.049 xctest[54929:5148343] [TRACE  ] [IN ]: Rx value received 1 bytes: . [0x00]
2015-07-04 19:55:20.049 xctest[54929:5148343] [TRACE  ] [IN ]: Ignoring single 0x00 char
2015-07-04 19:55:20.049 xctest[54929:5148343] [TRACE  ] [IN ]: Rx value received 2 bytes: . [0x14] . [0x10]
2015-07-04 19:55:20.050 xctest[54929:5148304] [TRACE  ] [IN ]: Finish reading
2015-07-04 19:55:20.050 xctest[54929:5148304] [TRACE  ] [IN ]: Receive: . [0x14]
2015-07-04 19:55:20.050 xctest[54929:5148304] [DEBUG  ] [IN ]: Read 1 bytes, actually received 2 bytes
2015-07-04 19:55:20.050 xctest[54929:5148304] [TRACE  ] [IN ]: 1 bytes in incoming buffer remaining for next receive
2015-07-04 19:55:20.051 xctest[54929:5148304] [DEBUG  ] [IN ]: Reading 1 bytes ...
2015-07-04 19:55:20.051 xctest[54929:5148304] [TRACE  ] [IN ]: Having current receive buffer: . [0x10]
2015-07-04 19:55:20.051 xctest[54929:5148304] [TRACE  ] [IN ]: Start reading
2015-07-04 19:55:20.052 xctest[54929:5148304] [TRACE  ] [IN ]: Finish reading
2015-07-04 19:55:20.052 xctest[54929:5148304] [TRACE  ] [IN ]: Receive: . [0x10]
2015-07-04 19:55:20.052 xctest[54929:5148304] [DEBUG  ] [IN ]: Read 1 bytes, actually received 1 bytes
2015-07-04 19:55:20.055 xctest[54929:5148304] [TRACE  ] [IN ]: Ble clear buffer
2015-07-04 19:55:20.055 xctest[54929:5148304] [DEBUG  ] [OUT]: Sending 3 bytes
2015-07-04 19:55:20.055 xctest[54929:5148304] [TRACE  ] [OUT]: Send: A [0x41] . [0x81]   [0x20]
2015-07-04 19:55:20.056 xctest[54929:5148304] [TRACE  ] [OUT]: BLE sending bytes range from 0 length 3
2015-07-04 19:55:20.056 xctest[54929:5148304] [DEBUG  ] [IN ]: Reading 1 bytes ...
2015-07-04 19:55:20.056 xctest[54929:5148304] [TRACE  ] [IN ]: Start reading
2015-07-04 19:55:20.123 xctest[54929:5148356] [TRACE  ] [IN ]: Rx value received 1 bytes: . [0x00]
2015-07-04 19:55:20.124 xctest[54929:5148356] [TRACE  ] [IN ]: Ignoring single 0x00 char
2015-07-04 19:55:21.174 xctest[54929:5148343] [TRACE  ] [IN ]: Rx value received 5 bytes: r [0x72] e [0x65] a [0x61] d [0x64] y [0x79]
4ntoine
I forgot to say i've tested with Arduino Uno r3. i've just tested uploading to Arduino Mega2560 and it works - Mega's bootloader replies as expected and uploading succeed. What's wrong with Uno?
