Topic: AT+CMSS TO SEND SMS TO MULTIPLE RECIPIENTS (Read 17521 times) previous topic - next topic
pavankumar
For the last two days I have been working on sending SMS to multiple recipients through AT commands.
I have been modifying the code that I attached to this post.
Last night I got to know from the link I address here,
http://www.developershome.com/sms/sendSmsByAtCommands.asp     that we ought to use the AT+CMSS in order to send multiple sms.
And that it sends message from the sms storage area in sim.I tried through this way........
  gsm.print("AT+CMGF=1\r");
  delay(100);
  gsm.println("AT + CMSS=3,\"*********\"");
  gsm.println("AT + CMSS=3,\"***********\"");
  gsm.println("AT + CMSS=3,\"**********\"");
  delay(100);
  gsm.println((char)26);
  delay(100);
  gsm.println();
  delay(5000);
  gsmpower();
It's working for me but only sending message to the first number.
Can you people please suggest me the way to use AT+CMSS command help my project complete.!!!!
Thanks in advance!!!
Regards
PavanKumar
mistergreen
You probably want this
http://forum.arduino.cc/index.php?topic=243348.0
hecanet
  delay(100);
  delay(100);
  delay(100);
  gsm.println();
  delay(5000);
  gsmpower();
Regards
PavanKumar
A quick workaround is to create multiple void functions and then call those in your void loop. For instance:
    str="hello world"
    sendSMS1();
    sendSMS2();
    sendSMS3();
    sendSMS4();
    sendSMS5();
    delay(2000);
void sendSMS1() //you have to create this for each of the sendSMS* functions.
  for(int i=0;i<=5;i++){
  Serial.println("enter for loop");
  gsm.print("AT+CMGF=1");
  delay(80);
  gsm.println("AT + CMGS = \"number1\"); // for sendSMS2, use the corresponding number, so also for the remaining from 3 to 5.
  delay(80);
  gsm.println(str);
  delay(80);
  delay(80);
  Serial.print("sending message to");
  Serial.println(num);
  gsmpower();
  i++;
Admittedly, there might be faster and more efficient ways, but this method works...and that is the bottom line.
Enjoy coding.
PaulS
Quote
Nonsense. It doesn't even compile.
pavankumar
I know this but it would be tiresome. Can I use better logic here
dannable
Put the code that sends the message in a separate procedure, then use a for...next loop, passing each number to the procedure in turn.
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
Messach99
Put the recipients' phone numbers into an array and use a loop to run through the array while sending an sms to each of the phone numbers.
Note: AT commands for sending an sms should be inside the loop.
MACKYDONALD
  delay(100);
  gsm.println("AT + CMSS=3,\"*********\"");    //why dont you try to put a delay between the different receiver
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  gsm.println();
  delay(5000);
  gsmpower();
galerivs
so, did you solve the problem?
what is the solution?
