Topic: Combining electret microphones?  (Read 740 times) previous topic - next topic
benx97
Hey,
New to the forum but not new to Arduino! I have a silly question that I just couldn't find the answer to online.
I'm building a box that needs to pick up audio from multiple directions. Audio quality isn't that important- the sound should be distinct.
What happens if I connect two or three electret microphones together? What will the output be? I figure it won't be anything usable, but I couldn't find anything online about it.
Thanks!
Ben
DVDdoug
Quote
If you connect them together* you won't get any directional information!
Do you know how to connect one electret?    It requires power, an amplifier, and a biasing circuit.   (Or you can buy a board from SparkFun will the mic and the circuitry.)
The Arduino has 6 analog inputs, and you can connect each mic to a separate input.
Note that an electret mic by itself is non directional (omnidirectinal).   It's slightly  more sensitive from the front, and mostly at high frequencies.    At low & mid frequencies it picks-up sound nearly equally from all directions.
* You'd need a mixer (a summing amplifier) or resistive mixer circuit if you wanted to mix the signals, but you don't want to do that anyway.
