Topic: OBD II Bike Connector - Pass via bluetooth (Read 89569 times) previous topic - next topic
aster94
I've looked at your code, and I'm truly impressed. Good job!
Thanks :D i really appreciate!
can I ask why are you reverse engineering the KDS instead of writing a software from zero? Are there some
hidden features which are not described in the ISO 14230-3?
Scissor
So far I've (mostly together with Trib a couple of years ago) found that most features described in the ISO 14230 documents are not supported by Kawasaki, or at least my Z750 from 2004. By decompiling the KDS software I hope to find which functions are supported, and more importantly, which manufacturing specific data bytes are required.
For example, as far as I know, for Kawasaki it is still unknown which requests are necessary to start actuator tests. And also if we manage to get the key for the Security Access, we may be able to do more advanced stuff.
TriB
Scissor was faster  8)
Yes, reprogramming the ECU, changing the immobilizer / learning new keys, driving/testing motors & sensors and stuff. Faking values, setting a required RPM for testing...
Reading/Writing the firmware is described within the ISO-Protocol, but does not work like that.
Testing the fan, exhaust valve, etc. works fine with Suzuki, but not with Kawasaki. There must be a difference, which the KDS-Software got inside, somewhere.
Tried to unpack the Healtech Software, but did not get further, due to no obvious tables or information I understand.
It was easier just to sniff the data via USB and also use the example files or own recordings from that software.
That way I could optimize several Suzuki calculations and understand the DTC stuff better.
The Kawa conversions are resilient, by reverse engineering the KDS-Software (but in another way) and some mathematical findings from Scissor  :D
Hiddenvision
Not promising but
disassembling and understanding software is one of my abilities.
Happy to look if needed.
HV.
aster94
All this would be astonishing! I am planning to stay on a "softer" level and stop my library at error codes and sensors
maybe fan tests, and some little other stuff but anyway i am not planning to do too deep
Scissor
#140
Apr 09, 2020, 06:18 pm Last Edit: Apr 09, 2020, 06:19 pm by Scissor
Breakthrough! :) I discovered how to get security access to the ECU!
The procedure is as follows:
1. A seed is requested, which the ECU will provide in its response.
2. You will have to respond by sending a matching key that is checked by the ECU.
However, non of this is described in the ISO 14230 documents as it's manufacturer specific. So I was afraid that the seed-key pairs were matched through complex encryption algorithms. But fortunately I have discovered that it is actually extremely simple.
There are just three hard-coded seed-key pairs.
Code: [Select]
Seed 13 52 43 64 75
Key  63 27 53 67 42
Seed 57 48 58 49 58
Key  30 20 39 48 74
Seed 58 37 48 45 95
Key  58 49 57 69 84
For example. this is what I did today as a first successful test.
I got 13 52 43 64 75 as a seed.
Code: [Select]
TX 80 11 F1 02 27 01 AC
RX 80 F1 11 08 67 01 13 52 43 64 75 34 A7
So, the matching key is 63 27 53 67 42.
Code: [Select]
TX 80 11 F1 07 27 02 63 27 53 67 42 38
RX 80 F1 11 03 67 02 34 22
Done!
TriB
Wow! Great  :smiley-eek:
I´ve read that functionality somewhere... Must have been somewhere in one of the 3 ISO14230 or the KWP2000 protocol. But too long ago, that I can remember. But it was in there!
From that, they created the OBD standard, which uses a similar functionality. Many manufacturers are sending the very same "seed" all the time, so it also is just a ridiculous safety wall :D
Someone hacked his Prius and overtook steering and acceleration via OBD2 and CAN-Bus. Everything with a single key, found out after 10 minutes of bruteforcing :)
Are you now able to use the download function?
Do you have to enter a different mode, that the SID´s dont´t throw an error on a request, any more?
Scissor
Yes, it follows the ISO 14230 protocol. This is described in the ISO 14230-3 document. What surprised me most is that apparently the seed-key pairs are completely independent of the bike i.e. it should work for all Kawasaki motorcycles.
I have not tried to use other functionality yet. Because I am really focusing  to make sense of the decompiled KDS software. At this point I have a decent understanding of the possible requests, which I'm now writing down comprehensively.
For instance, I have found that once you have security access you can start a "programming" diagnostic session, instead of the "workshop" diagnostic session (this terminology is really used in the ISO 14230 documents). This is probably required to access all the other functions like actuator tests and downloading/uploading and so on.
I hope to have a complete understanding of all the possibilities in the following weeks.
aster94
Code: [Select]
Seed 13 52 43 64 75
Key  63 27 53 67 42
Seed 57 48 58 49 58
Key  30 20 39 48 74
Seed 58 37 48 45 95
Key  58 49 57 69 84
Interesting! actually I didn't understood how from 13 52 43 64 75 you extrapolated the 63 27 53 67 42
Could you explain?
Scissor
I have not tried yet to find out how the seed and key are related. Actually I think I'm not even going to try, as I believe there are most likely no other seed-key pairs.
Because I found that in the KDS software there are literally just three if statements that compare the received seed with the three hardcoded ones. If the match is found, it just sends the corresponding key.
Perhaps there is some connection e.g. it could be ASCII, mathematical operation or maybe some bitwise operation. But in the end it does not matter as I really believe there are just three seed-key pairs.
windoze_killa
Did you ever find a waterproof display and case?
What do I need:
  • Arduino Nano, BlendMicro or similar (included Bluetooth?)
  • Bluetooth-Shield (unless already included)
  • Waterproof LCD Display - Step II
  • Waterproof case - Step II
Engineers design things.....technicians make them work.
I don't need anti-static wrist straps.....an instructor years ago told me I had no potential.
TriB
Hi windoze_killa,
no, I´ve buried the idea of an external display.
All informations (except the gear) would be nice to have or just playing around.
So I decided to focus on the OBD II compatibility, so I can use any app or device.
Currently I´ve created the second version of an unique PCB design. There is an SPI for future purpose, which could probably being used for that.
Since I also got a Suzuki bike for racetracks, many optimizations have to be done in the code to speedup the communication. That´s my work for now  :smiley-yell:
windoze_killa
I am actually trying to get the data stream from the ECU to the cluster. I have captured some data but I am having no end of trouble working out what it all means. From what I can work out in is uni directional so there is no handshaking that I know of. I want to play around with a colour display for speed, tach, indicators, gear and clock. I know I can buy one but where is the fun in that.
TriB
I´m completely with you ;D
Found my drawings where to put what on a display (Voltage, Gear, etc) and a demo sketch, which was way to slow to update a little oled and handle the KDS.
Probably an ESP32 would be the better solution!
Since I got a small 3D printer, a case could be designed pretty fast. With the right plexiglass and silicone, it should be rain-proof!
Do you want to fetch the data from the ECU or directly from the tachometer?
What´s the struggle with your data? I guess I currently have all data and calculations available  8)
Right now, I create a data class, where I put everything in. Then I can optimize readings from temperature (which does not change so fluently) and speedup rpm, throttle or speed.
Suzuki reads all data at once, so there is even much more potential for performance!
Sadly lots of work and space for issues...
2gnospam
Noob here.  Great thread!  I am trying to help a friend out who wants to log ECU data from a Kawasaki SX-R 1500 jet ski to an AEM AQ-1 (available in CAN or OBII) versions.  Any idea where I should start.
