Topic: error: invalid conversion from 'const char*' to 'char' [-fpermissive] (Read 43023 times) previous topic - next topic
rremm2000
I've made a few global vars / constants to handle serial port input, ran into this error
junk.ino: In function 'void loop()':
junk.ino:35:13: error: invalid conversion from 'const char*' to 'char' [-fpermissive]
Error compiling.
I didn't declare this as a const char, just char so I could put new char data into it but, this error is got me confused?
Code: [Select]
bool serControl       = false;
int serIntIn          = 0;
char serCharIn     ="";
String serStringIn    = "";
const int SER_RET_INT       = 1;
const int SER_RET_CHAR      = 2;
const int SER_RET_STRING    = 3;
Serial.begin(19200); // opens serial port, sets data rate to 9600 bps
  //attachInterrupt(1, intCnt, RISING  ); // syntax attachInterrupt(interrupt, ISR, mode)
  //interrupts();
  //tickEvent = t.every(2000, intCnt); //doFreeRun is controlled by timer
serIntIn    = 0;
serCharIn   = "";
serStringIn = "";
It's a fool who looks for anything other than blood in the chambers of the human heart, for both passion and logic emanate from the human mind.
larryd
Using "const" prevents you from changing the variable in code.
Remove const from variables you change.
Edit, my mistake
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
rremm2000
Hopefully the "edit my mistake" was you realized that I don't have const before the error because the error is on line 35 which is
Code: [Select]
serCharIn   = "";
it's declared as a char not a const char?
If I misunderstood your post then please clarify
larryd
No technical PMs.
larryd
You need '  ' rather than "  "
Code: [Select]
int serIntIn          = 0;
char serCharIn        = ' ';  //<<<<<<< use ' apostrophes
  //interrupts();
  serIntIn    = 0;
  serCharIn   = ''; //<<<<<<< use ' apostrophes
  serStringIn = "";
No technical PMs.
rremm2000
Can I ask why I would need '' verses "" for a char verses a string?
Actually I tried it with single quotes and got the same error
If I just change the declaration I get.....
Build options changed, rebuilding all
junk.ino:15:25: error: empty character constant
Error compiling.
If I change the initialization
junk.ino:35:15: error: empty character constant
junk.ino:15:25: error: invalid conversion from 'const char*' to 'char' [-fpermissive]
Error compiling.
and if I change both I still have...
Error compiling.
larryd
'  char, is a single character variable like 'C' or '$'.
" String, is a string of characters like "now is the time for all good men to come to the aid of the party"
No technical PMs.
larryd
No technical PMs.
michinyon
You didn't get "the same error",  at all.
You tried to define a char variable with
char serCharIn = ''  ;
which is invalid.   That is two single quotes there,    and there has to be a char constant between them.  One char.   Not zero chars.  That's what "junk.ino:35:15: error: empty character constant" says.
A char is one char
A const char*  is a pointer to the beginning of an array of chars  (  which might be an array consisting of one element ).
itsacoolaccount
Code: [Select]
int serIntIn          = 0;
  //interrupts();
  serIntIn    = 0;
  serStringIn = "";
This is true, I had the same issue. Doing that fixed it for my code.
