Topic: Help with Ph sensor pin abbreviations (Read 80190 times) previous topic - next topic
crustyourmind
OK thanx
And finally, the temperature sensor is functional?
Thx and good day ;)
Débutant Arduino (UNO/NANO).... Mais motivé...
IDE Arduino 1.8.8 Debian SID
IDE Arduino 1.8.5 FreeBSD
wvmarle
I may assume it is. I've never tried it as it has several issues.
1) parameters of the sensor (a thermistor) are not known, so I have no idea on the actual temperature response.
2) the signal is fed through a cascade of total three(!!) OpAmps.Too hard to figure out that that does to the signal.
3) it's measuring the air temperature rather than the water temperature.
Note that the thermistor circuit is completely independent from the pH circuit, they only share the power supply. For some reason the majority of the components on that board are in fact related to the thermistor. It's overall a quite odd and seemingly overcomplicated circuit.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
crustyourmind
porlock
According to the schematic, the final op amp output should be a 2x........
Can you share schematic?
wvmarle
Schematic of that sensor board you can quite easily find online.
Do note that the pH is a bit temperature dependent so for best results use a water temperature probe (waterproof thermistor or digital D18B20 sensor).
crustyourmind
I received this board yesterday
To calibrated it , I putted the probe in water with ph 7.2 and I calibrate the data with the blue potentiometer close to BNC
I tested in my aquarrium : 7.4, my coffee 4.9 and lemonade lemon juice 3.5
I think, it works.
Thanx for this thread ;)
wvmarle
It works - but your calibration will be off. Water is NOT suitable for calibration, you must use a buffer solution. Preferably two.
crustyourmind
OK thx, I'll looking for 2 buffer solutions
Now I ' try to calibrate the limit red led
crustyourmind
I've Just tested with 2 buffer solutions received today
So at 4.01 PH, I've got theses value :  mesure 601 and voltage 2,95
The ph-step is : 2,95 - 2,5 / 2,99 = 0,15
I've adjust this var is this formula
  // PH_probe = PH7 - ((voltage@PH7 - voltage@probe) / PH_step)
  float Po = 7 + ((2.5 - voltage) / 0.18);
And it works fine
I check with the second buffer solution (6,86) and the return is 6,82, so I consider this value acceptable
A great thx for your help
Krheigh
I have this sensor an have hard time to get it work.
I think it's broken.
No matter how many turns (both ways) I screw the pot closest to bnc I only get 4,95v out of OP pin.
Bnc shorted.
aCiDcHaOZ
Bnc shorted.
Same problem on 2 different boards. Still looking for a solution :(
ainurasyar
Saya memiliki masalah. Sensor pH saya nilai pH rendah output nilai ADC ikut rendah sedangkan nilai pH tinggi output nilia ADC ikut tinggi dimana hasil yang saya dapat tidak akurat atau diatas nilai 14 pH. Mohon bantuannya
adam_289
Idk if this has already been posted. But someone has done all the hard work with this sensor. I think everything you'll need to get it working will be here:
https://scidle.com/how-to-use-a-ph-sensor-with-arduino/
