Topic: how can I upload program in Arduino uno r3  (Read 625 times) previous topic - next topic
sonirahul111
Arduino: 1.6.6 Hourly Build 2015/07/03 10:41 (Windows 7), Board: "Arduino Uno"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x5d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x5d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x5d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x5d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x5d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x5d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x5d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x5d
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x5d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x5d
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
  enabled in File > Preferences.
CrossRoads
Does the Loopback Test pass? If not, likely there is a driver problem you need to resolve first.
Check the Tools:Serial Port, see if the correct COM port shows up. If not, check the Device Manager and see if the COM port has an ! over it, and fix that.
