Hello i know is this is a old project of mine And i didn't finish it. I actually just came back to it and wanted to see If I can finish it and see where it goes.
To answer ClumsyPilot question for some unknown reason that didn't work. I couldn't even get the Led to turn on when power is applied. But if i change 13 to LED_BUILTIN That did turn on the led blinking it before it went to sleep.
however when i change from attachInterrupt(0, onInt, RISING); to attachInterrupt(0, onInt, LOW); Nothing changed. Still wouldn't wake up.
New updated sketch based off the old one.
Arduino ZERO PRO low-power sleep mode with wakeup upon external interrupt
(example sketch)
Add a button on digital pin 0, with an additional pull-up resistor.
Add an LED on digital pin 3 (don't forget resistor)
NOTE: LED might not appear to toggle, or it might flash, that is because of switch bounce.
(Electrically noisy contacts)
I think there is a filtering option to digitally filter external interrupts.
Might check that out in the future.
bool ledState = true;
pinMode(3, OUTPUT); // Output for an LED that is toggled on/off upon interrupt
pinMode(LED_BUILTIN, OUTPUT); // Flashing LED pin
// I could actually use the ARM macro thingies and set registers
// and what not to do the same exact thing,
// But I'm lazy so I just cheated and used this arduino function
SCB->SCR |= 1<<2; // Enable deep-sleep mode
// Set the EIC (External Interrupt Controller) to wake up the MCU
// on an external interrupt from digital pin 0. (It's EIC channel 11)
EIC->WAKEUP.reg = EIC_WAKEUP_WAKEUPEN11;
Serial.println("Sleeping in 3");
toggleAndDelay();
Serial.println("Sleeping in 2");
toggleAndDelay();
Serial.println("Sleeping in 1");
toggleAndDelay();
__WFI(); // This is the WFI (Wait For Interrupt) function call.
// Called upon interrupt of digital pin 0.
void onInt()
ledState = !ledState;
digitalWrite(3, ledState);
// This just toggles the LED on pin 13, and delays.
// Used in between the sleep countdown Serial.println()
void toggleAndDelay()
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(LED_BUILTIN, LOW);
