Topic: SimpleSDAudio Library Help *FIXED* (Read 532 times) previous topic - next topic
AdamAngle
Jul 23, 2015, 05:25 am Last Edit: Jul 23, 2015, 05:52 am by AdamAngle Reason: It works now.
I have just recently downloaded and uploaded the SimpleSDAudio Library from this website and tried the Bare Minimum with Debug sample. I tried it a few times and it worked great, but after about 9 times of using it, the thing stopped, saying "MUSICSAMPLEAUD.WAV not found on card! Error code: 1" The file was on there and SD Card wasn't locked or jammed.Thanks!
The only thing i mainly changed was using an SD Card shield instead of an SD Card itself.
EDIT: Nevermind! All of a sudden worked!
Ubuntu is the best operating system in the world.
xl97
* What Arduino board are you using?
If not using the shield.. are you using a voltage divider or some sort of logic level shifter IC to get the Arduino to talk to the +3.3v the SD needs?
Perhaps try formatting the SD card each time as well..
