Topic: Arduino uno, adafruit motor shield and colorPAL sensor (Read 546 times) previous topic - next topic
b8b8
Hello, I am building a robot using arduino uno, a motor shield and the sensor colorPAL. I've got colorPAL demo code from  http://learn.parallax.com/colorpal-arduino-demo, and it worked properly. Then I made a code for the motors, and robot went forward. All ok till now.
   Then I wrote an if statement, using data obtained from colorPAL. Unfortunately, motorE, connected in port M1 of motor shield, stopped working. Could someone explain for me why if statement is causing that trouble for M1 port? Motor shield uses digital pins 3,4,5,6,7,8,9,10,11,12 of arduino board.
Here's the code:
#include <AFMotor.h>
AF_DCMotor motorE(1);
AF_DCMotor motorD(2);
#include <SoftwareSerial.h>
const int sio = 2;            // ColorPAL connected to pin 2
const int unused = 255;         // Non-existant pin # for SoftwareSerial
const int sioBaud = 4800;
const int waitDelay = 200;
// Received RGB values from ColorPAL
int red;
int grn;
int blu;
// Set up two software serials on the same pin.
SoftwareSerial serin(sio, unused);
SoftwareSerial serout(unused, sio);
  reset();                  // Send reset to ColorPal
  serout.begin(sioBaud);
  pinMode(sio, OUTPUT);
  serout.print("= (00 $ m) !"); // Loop print values, see ColorPAL documentation
  serout.end();              // Discontinue serial port for transmitting
  serin.begin(sioBaud);            // Set up serial port for receiving
  pinMode(sio, INPUT);
  readData();
  motorD.run(FORWARD);
  motorE.run(FORWARD);
  motorD.setSpeed(180);
  motorE.setSpeed(180);
  if((red>130)&&(red<150)&&(grn>110)&&(grn<130)&&(blu>150)&&(blu<170)){
  motorD.run(BACKWARD);
  motorE.run(BACKWARD);
  delay(2000);}
// Reset ColorPAL; see ColorPAL documentation for sequence
void reset() {
  delay(200);
  digitalWrite(sio, LOW);
  while (digitalRead(sio) != HIGH);
  delay(80);
  delay(waitDelay);
void readData() {
  char buffer[32];
  if (serin.available() > 0) {
    // Wait for a $ character, then read three 3 digit hex numbers
    buffer[0] = serin.read();
    if (buffer[0] == '$') {
      for(int i = 0; i < 9; i++) {
        while (serin.available() == 0);     // Wait for next input character
        buffer = serin.read();
        if (buffer == '$')               // Return early if $ character encountered
          return;
      parseAndPrint(buffer);
      delay(10);
// Parse the hex data into integers
void parseAndPrint(char * data) {
  sscanf (data, "%3x%3x%3x", &red, &grn, &blu);
  char buffer[32];
  sprintf(buffer, "R%4.4d G%4.4d B%4.4d", red, grn, blu);
  Serial.println(buffer);}
PaulS
Code: [Select]
Youneedtogetyourspacekeyfixed.
Quote
You need to post a link to the motor shield. It seems unlikely that it takes 10 pins to set direction and speed of two motors.
