Topic: .hex export / upload feature (Read 2171 times) previous topic - next topic
Elektrik1
Hello,
I have an situation where I do compile sketch on my desktop PC, and need to upload sketch to device (standalone) with notebook. I find it very inconvenient, as upload should be done via CMD (avrdude), also hex is being exported to some random temporary directory. I think it could be tweaked a bit to have an export dialog where you can at least select path to export, also feature to upload .hex file directly without compiling a sketch, as in this situation libraries/projects needs to be in sync...
I don't see any restrictions over doing it really easily.
Thanks, no offense, just an idea  :smiley-roll-sweat:
PaulS
Quote
The IDE is open source. Have at it. When you get it working, post the changes back to the source repository and create a pull request. Since it's so easy, I'll expect a report on Monday.
Elektrik1
#2
Aug 07, 2015, 02:00 am Last Edit: Aug 07, 2015, 02:08 am by Elektrik1
Hehe, you are really good into involving people to contribute. Easily, I mean it should not be difficult execute avrdude command line (same one used for uploading sketches, just with different, selectable hex path) from IDE directly.
Inspired by you I tried to build latest github sources myself, and ended up by bunch of errors. It may be because I use latest eclipse version (mars), or any kind of stuff, as I did not find any proper references explaining how IDE could be compiled standalone (or what configuration is necessary), I threw it away and accidentally found small tool for my issue to be solved - XLoader, uploads went just fine.
If any proper reference exists, explaining what guys you did here, and how to contribute developing it, instead of spending millions of hours trying to just build sources - would be just great, I think a lot more devs would contribute.
http://imgur.com/7e99CPF
http://imgur.com/FyvPcaL
q2dg
I think "Sketch->Export compiled binary" menu option of IDE (1.6.5) is what you want
Isaac96
Where do the binaries get put?
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
spycatcher2k
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
