Topic: Grove Temperature With Arduino Yun (Read 1 time) previous topic - next topic
YZDYZD
Aug 10, 2015, 08:36 am Last Edit: Aug 10, 2015, 08:46 am by YZDYZD
I try to test Grove - Infrared Temperature Sensor on Ardiuno Yun with the sample code but it dose not work in the console it show that the object temperature is out of range all the time. However, when I try to test it on Ardiuno Uno, it works fine. The following code is the one I use to with Grove Temperature sensor.
HERE IS THE CODE:
//   Function: Measure the measure the Surrounding temperature around the sensor
//           and the temperature of the target which is in front of the sensor.
//           And print the result on the serial monitor.
//   Hardware: Grove - Infrared Temperature Sensor
//   Arduino IDE: Arduino-1.0
//   Author:    Bruce.Qin
//   Date:     Nov 28,2011
//   Version: v1.0 modified by FrankieChu at Jan 24,2013
//   by www.seeedstudio.com
//  This library is free software; you can redistribute it and/or
//  modify it under the terms of the GNU Lesser General Public
//  License as published by the Free Software Foundation; either
//  version 2.1 of the License, or (at your option) any later version.
//  This library is distributed in the hope that it will be useful,
//  but WITHOUT ANY WARRANTY; without even the implied warranty of
//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
//  Lesser General Public License for more details.
//  You should have received a copy of the GNU Lesser General Public
//  License along with this library; if not, write to the Free Software
//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include <math.h>
#define SUR_TEMP_PIN A0 // Analog input pin connect to temperature sensor SUR pin
#define OBJ_TEMP_PIN A1 // Analog input pin connect to temperature sensor OBJ pin
float temp_calibration=0;       //this parameter was used to calibrate the temperature
//float objt_calibration=0.000; //this parameter was used to calibrate the object temperature
float temperature_range=10;    //we make a map of temperature-voltage according to sensor datasheet. 10 is the temperature step when sensor and
                               //object distance is 9CM.
float offset_vol=0.014;        //this parameter was used to set the mid level voltage,when put the sensor in normal environment after 10 min,
                               //the sensor output 0.For example,the surrounding temperature is 29℃,but the result is 27℃ via the sensor,
                               //you should set the reerence to 0.520 or more,according to your sensor to change.
                               //the unit is V
float tempValue = 0;
float objtValue= 0;
float current_temp=0;
float temp=0;
float temp1=0;
float temp2=0;
unsigned int temp3=0;
const float reference_vol=0.500;
unsigned char clear_num=0;//when use lcd to display
float R=0;
float voltage=0;
long res[100]={
                 318300,302903,288329,274533,261471,249100,237381,226276,215750,205768,
                 196300,187316,178788,170691,163002,155700,148766,142183,135936,130012,
                 124400,119038,113928,109059,104420,100000,95788,91775,87950,84305,
                 80830,77517,74357,71342,68466,65720,63098,60595,58202,55916,
                 53730,51645,49652,47746,45924,44180,42511,40912,39380,37910,
                 36500,35155,33866,32631,31446,30311,29222,28177,27175,26213,
                 25290,24403,23554,22738,21955,21202,20479,19783,19115,18472,
                 17260,16688,16138,15608,15098,14608,14135,13680,13242,12819,
                 12412,12020,11642,11278,10926,10587,10260,9945,9641,9347,
                 9063,8789,8525,8270,8023,7785,7555,7333,7118,6911};
float obj [13][12]={
/*0*/             { 0,-0.274,-0.58,-0.922,-1.301,-1.721,-2.183,-2.691,-3.247,-3.854,-4.516,-5.236}, //
/*1*/             { 0.271,0,-0.303,-0.642,-1.018,-1.434,-1.894,-2.398,-2.951,-3.556,-4.215,-4.931},  //→surrounding temperature,from -10,0,10,...100
/*2*/             { 0.567,0.3,0,-0.335,-0.708,-1.121,-1.577,-2.078,-2.628,-3.229,-3.884,-4.597},   //↓object temperature,from -10,0,10,...110
/*3*/             { 0.891,0.628,0.331,0,-0.369,-0.778,-1.23,-1.728,-2.274,-2.871,-3.523,-4.232},
/*4*/             { 1.244,0.985,0.692,0.365,0,-0.405,-0.853,-1.347,-1.889,-2.482,-3.13,-3.835},
/*5*/             { 1.628,1.372,1.084,0.761,0.401,0,-0.444,-0.933,-1.47,-2.059,-2.702,-3.403},
/*6*/             { 2.043,1.792,1.509,1.191,0.835,0.439,0,-0.484,-1.017,-1.601,-2.24,-2.936},
/*7*/             { 2.491,2.246,1.968,1.655,1.304,0.913,0.479,0,-0.528,-1.107,-1.74,-2.431},
/*8*/             { 2.975,2.735,2.462,2.155,1.809,1.424,0.996,0.522,0,-0.573,-1.201,-1.887},
/*9*/             { 3.495,3.261,2.994,2.692,2.353,1.974,1.552,1.084,0.568,0,-0.622,-1.301},
/*10*/            { 4.053,3.825,3.565,3.27,2.937,2.564,2.148,1.687,1.177,0.616,0,-0.673},
/*11*/            { 4.651,4.43,4.177,3.888,3.562,3.196,2.787,2.332,1.829,1.275,0.666,0},
/*12*/            { 5.29,5.076,4.83,4.549,4.231,3.872,3.47,3.023,2.527,1.98,1.379,0.72}
   Serial.begin(9600); // initialize serial communications at 9600 bps
   analogReference(INTERNAL);//set the refenrence voltage 1.1V,the distinguishability can up to 1mV.
   //analogReference(INTERNAL1V1);//(mega only)set the refenrence voltage 1.1V,the distinguishability can up to 1mV.
   measureSurTemp();//measure the Surrounding temperature around the sensor
   measureObjectTemp();
float binSearch(long x)// this function used for measure the surrounding temperature
   int low,mid,high;
   low=0;
   //mid=0;
   high=100;
   while (low<=high)
      mid=(low+high)/2;
      if(x<res[mid])
         low= mid+1;
      else//(x>res[mid])
         high=mid-1;
   return mid;
float arraysearch(float x,float y)//x is the surrounding temperature,y is the object temperature
   int i=0;
   float tem_coefficient=100;//Magnification of 100 times
   i=(x/10)+1;//Ambient temperature
   voltage=(float)y/tem_coefficient;//the original voltage
   //Serial.print("sensor voltage:\t");
   //Serial.print(voltage,5);
   //Serial.print("V");
   for(temp3=0;temp3<13;temp3++)
      if((voltage>obj[temp3])&&(voltage<obj[temp3+1]))
         return temp3;
float measureSurTemp()
   unsigned char i=0;
   float current_temp1=0;
   int signal=0;
   tempValue=0;
   for(i=0;i<10;i++)       //
      tempValue+= analogRead(SUR_TEMP_PIN);
      delay(10);
   tempValue=tempValue/10;
   temp = tempValue*1.1/1023;
   R=2000000*temp/(2.50-temp);
   signal=binSearch(R);
   current_temp=signal-1+temp_calibration+(res[signal-1]-R)/(res[signal-1]-res[signal]);
   Serial.print("Surrounding temperature:");
   Serial.print(current_temp);
   return current_temp;
float measureObjectTemp()
   unsigned char i=0;
   unsigned char j=0;
   float sur_temp=0;
   unsigned int array_temp=0;
   float temp1,temp2;
   float final_temp=0;
   objtValue=0;
   for(i=0;i<10;i++)
      objtValue+= analogRead(OBJ_TEMP_PIN);
      delay(10);
   objtValue=objtValue/10;//Averaging processing
   temp1=objtValue*1.1/1023;//+objt_calibration;
   sur_temp=temp1-(reference_vol+offset_vol);
   Serial.print("\t Sensor voltage:");
   Serial.print(sur_temp,3);
   Serial.print("V");
   array_temp=arraysearch(current_temp,sur_temp*1000);
   temp2=current_temp;
   temp1=(temperature_range*voltage)/(obj[array_temp+1][(int)(temp2/10)+1]-obj[array_temp][(int)(temp2/10)+1]);
   final_temp=temp2+temp1;
   if((final_temp>100)||(final_temp<=-10))
      Serial.println ("\t out of range!");
         Serial.print("\t object temperature:");
         Serial.println(final_temp,2);
sonnyyu
https://www.arduino.cc/en/Reference/AnalogReference
The official document is misleading.
ATmega32U4 of Atmel document
http://academy.cba.mit.edu/classes/embedded_programming/doc7766.pdf
Quote
Internal reference voltages of nominally 2.56V or AVCC are provided On-chip. The voltage reference may be externally decoupled at the AREF pin by a capacitor for better noise performance
Page 292
INTERNAL Reference=2.56 V
http://forum.arduino.cc/index.php?topic=310672.msg2154380#msg2154380
YZDYZD
Sorry, can you explain to me in details, I do not get the point.
Thank you very much
sonnyyu
Code: [Select]
Set the reference voltage 2.56 V at Yun !
sonnyyu
Move most of business logic into Linux:
Code: [Select]
long res[100]={
Use Excel Curve Fitting function to get
y=f(x)
Then only read raw voltage of
Code: [Select]
Do convert at Linux side.
jessemonroy650
@YZDYZD
please use markup when posting code. when you do this, your code will look similar to SonnyYu's code.
See attached Images
TIA
Jesse
