Topic: Rotary encoder output to lcd 1602a (Read 15449 times) previous topic - next topic
williamjcoates
I am new to arduino and need some direction.
I would like to output the position of my rotary encoder shaft to a lcd screen. The shaft position would start at 1 and terminate at 100, which would be 1 full revolution of the shaft. So if the shaft was turned  1/4 turn to the right the lcd readout would indicate 25.00. And a 1/2 turn would indicate 50.00 on the lcd readout. If the shaft was rotated to the left the lcd readout would indicate 75.00 or 50.00 if rotated 1/2 turn to left.
I have Arduino 1.6.5 installed on my computer.
I have a
Mega 2560 board
1620a lcd screen
Yumo-E6B2-CWZ3E Rotary encoder with a resolution 1024 P/R
I also have a basic adruino kit which includes a bread board, wires, resisters etc.
I have looked through tutorials and examples but havn't come across anything resembling this. Does anyone have any sample sketches and wiring diagrams that I could work with.
Bill
CrossRoads
Wow, 100 pulse/revolution rotary encoders are expensive!
http://www.digikey.com/product-search/en?pv395=4&FV=fff4001e%2Cfff80033&k=rotary+encoder&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
I don't see a datasheet for Yumo-E6B2-CWZ3E.
Counting encoder pulses and displaying them is pretty straightforward.
See the code here for counting them, change as needed for your display.
http://forum.arduino.cc/index.php?topic=318170.0
williamjcoates
hi,
Thanks for the reply. Really appreciate the help.
This is the encoder i'm using.
https://www.sparkfun.com/products/11102
I followed your link and used this code. I was able to hook everything up and have it output to serial. How can I calibrate or modify this sketch so that one revolution of the shaft would display 100.00. if I turn CCW 1/4 turn it would display 75.00. There would be a dial on the encoder shaft that would be marked out evenly 1 - 100. I also want to use the high resolution of this encoder to indicate  the dial position when it is between a number ie: 12.6572.
Once I can get it working and display it on the serial monitor I would like to have the encoder ouput to my lcd 1620a. I have no idea how to wire this to my adruino mega 2560 board, or how to include the lcd 1620a in the code.
Bill
/* Rotary encoder with attachInterrupt
Counts pulses from an incremental encoder and put the result in variable counter.
Taking also into account the direction and counts down when the rotor rotates in
the other direction.
This code is used attachInterrupt 0 and 1 which are pins 2 and 3 moust Arduino.
For more information about attachInterrupt see:
http://arduino.cc/en/Reference/AttachInterrupt
created 2014
by Ben-Tommy Eriksen
https://github.com/BenTommyE/BenRotaryEncoder
// Encoder connect to digitalpin 2 and 3 on the Arduino.
volatile unsigned int counter = 0;  //This variable will increase or decrease depending on the rotation of encoder
  Serial.begin (9600);
  //Setting up interrupt
  //A rising pulse from encodenren activated ai0(). AttachInterrupt 0 is DigitalPin nr 2 on moust Arduino.
  attachInterrupt(0, ai0, RISING);
  //B rising pulse from encodenren activated ai1(). AttachInterrupt 1 is DigitalPin nr 3 on moust Arduino.
  attachInterrupt(1, ai1, RISING);
  // Send the value of counter
  Serial.println (counter);
void ai0() {
  // ai0 is activated if DigitalPin nr 2 is going from LOW to HIGH
  // Check pin 3 to determine the direction
  if(digitalRead(3)==LOW) {
    counter++;
  }else{
    counter--;
void ai1() {
  // ai0 is activated if DigitalPin nr 3 is going from LOW to HIGH
  // Check with pin 2 to determine the direction
  if(digitalRead(2)==LOW) {
    counter--;
  }else{
    counter++;
jcallen
Try:
Code: [Select]
Serial.println(counter * 100.0 / 1024);
williamjcoates
I tried it and it moved the decimal place to 0.00.
Full rotation goes to 6400.00
Can't be that difficult but beyond me at the moment.
Wawa
#5
Aug 15, 2015, 11:36 pm Last Edit: Aug 15, 2015, 11:39 pm by Wawa
If a full rotation goes to 6400.00, divide it by another 64.
1024/64 = 16, so 100/16= 6.25
Serial.println(counter * 6.25); // default two decimal places
or
Serial.println(counter * 6.25, 3); // three decimal places
Leo..
MarkT
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
free-bee
#7
Aug 16, 2015, 03:13 am Last Edit: Aug 16, 2015, 03:14 am by free-bee
Wow, Sparkfun is so expensive!
http://www.ebay.com/itm/360P-R-Incremental-Rotary-Encoder-AB-phase-encoder-6mm-Shaft-W-coupling-New-/141686141372?hash=item20fd26f1bc
Just wanna throw out that this one is the closest one to what OP bought. OP's has almost three times the p/r of what you posted.
williamjcoates
or
Leo..
hi Leo,
Thanks for the input. I tried your suggestion but no luck. I was also mistaken about the total value after 1 revolution. it showed 65535 in the serial monitor. I also noticed the display in the serial monitor was jumpy .
I guess this is because of the high resolution of the encoder 1024/pr. I wanted a high res encoder to track the movement of the shaft to something like 4 decimal places. so if the shaft stopped at 10 it would show 10.0000. The idea of this project is to be able to accurately measure the distance between the start and stop position of the encoder shaft. For now I would just take the start value displayed and subtract it from the stop value. In the future I would like to be able to display the results in a graph.
Bill
TomGeorge
#9
Aug 16, 2015, 08:50 am Last Edit: Aug 16, 2015, 08:52 am by TomGeorge
The  encoder you have is a chinese knock off of an Omron encoder.
Can you please post a copy of your sketch, using code tags?
They are made with the  </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Tom.... :)
Everything runs on smoke, let the smoke out, it stops running....
TomGeorge
That ebay one is a bit old too.
One of the notes in the spec says.
Quote
Notice:AB 2phase output must not be directly connected with VCC, otherwise, will burn the output triode, because different batches, and may not have the terminal
So if you use it you will have to wait for it to stop humming and warm up.
Also some batches have no terminals.
Tom.... :)
Wawa
I think if you want exactly 100 steps/rev, you should use an encoder that can produce 100 when divided by an integer.
e.g  1000 or 2000 steps, not 1024 steps.
Are you expecting a higher resolution than the encoder resolution?
Leo..
TomGeorge
If you have 1024 steps per revolution and you want 100 steps with 1 step precision, it is not going  to happen.
1024/100 = 10.24 steps per needed step.
You cannot get  0.24 of a step input.
The OEM, Omron and the chinese mob, quote a 100 and a 2000 ppr model.
The 2000 model will give you 2000/100=20 step per needed step.
1/20= 0.05 resolution.
What is your application?
Tom.... :)
williamjcoates
Thanks for replying,
With this project I want to use the rotary encoder to indicate the position of a dial. In this case a dial for a safe. Safe dials are numbered 0-100. By attaching the encoder to the dial i would be able to relay the exact position of the dial to an lcd readout. So if I set the safe dial at 0, turn on the adruino board and rotate the dial to the right and stop in the middle of 10-11 the encoder would relay the position and print to screen something like 10.56. If I rotate the dial to the left past zero and stop on 75, the encoder would read this and print to screen 75. I know I have a high resolution encoder but was hoping I could still make it work...
Maybe by using the map() function  with something like this
Code: [Select]
Serial.print(map(counter, 0, max_encoder_count, 0, 99))
My hardware setup is very basic at this point. the encoder is wired to my mega 2650 board this way
Encoder  Wire Black Out A to Digital Pin 2 Mega Board
Encoder  Wire White Out B to Digital Pin 3 Mega Board
Encoder  Wire Brown 5V to 5V Mega Board
Encoder  Wire Blue OV(Common) to GND Mega Board
I have the Board Plugged into my laptop using the USB serial cable and view the results using the serial monitor in the adruino ide. I am using the following code example
Code: [Select]
created 2014
   // Serial.println (counter);
   Serial.print(map(counter, 0, max_encoder_count, 0, 99)).
void ai0() {
    counter++;
  }else{
    counter--;
void ai1() {
    counter--;
  }else{
    counter++;
This code does not compile due to the "max_encoder_count" was not declared error.
Any help in pointing me in the right direction would be greatly appreciated
Bill
MarkT
hi,
The code you quoted is not reliable as it samples only rising edges.
You have to sample rising and falling edges to get reliable quadrature decoding.
