Topic: [Risolto] Processing non riceve da TouchOSC (Read 562 times) previous topic - next topic
LoadDuinoUNO
Aug 16, 2015, 06:29 pm Last Edit: Aug 16, 2015, 07:03 pm by LoadDuinoUNO
Salve a tutti, ho un problema riguardante il progetto su: https://www.sparkfun.com/tutorials/152
I codici che ho caricato sono gli stessi del sito cioè per Arduino questo:
Code: [Select]
//----------------------Arduino code-------------------------
int message = 0;     //  This will hold one byte of the serial message
int redLEDPin = 11;   //  What pin is the red LED connected to?
int redLED = 0;          //  The value/brightness of the LED, can be 0-255
  Serial.begin(9600);  //set serial to 9600 baud rate
void loop(){
    if (Serial.available() > 0) { //  Check if there is a new message
      message = Serial.read();    //  Put the serial input into the message
   if (message == 'R'){  //  If a capitol R is received...
     redLED = 255;       //  Set redLED to 255 (on)
   if (message == 'r'){  //  If a lowercase r is received...
     redLED = 0;         //  Set redLED to 0 (off)
analogWrite(redLEDPin, redLED);  //  Write an analog value between 0-255
//----------------------------end Arduino code--------------------------------
E per processing quest'altro:
Code: [Select]
//-----------------Processing code-----------------
import oscP5.*;        //  Load OSC P5 library
import netP5.*;        //  Load net P5 library
import processing.serial.*;    //  Load serial library
Serial arduinoPort;        //  Set arduinoPort as serial connection
OscP5 oscP5;            //  Set oscP5 as OSC connection
int redLED = 0;        //  redLED lets us know if the LED is on or off
int [] led = new int [2];    //  Array allows us to add more toggle buttons in TouchOSC
  size(100,100);        // Processing screen size
  noStroke();            //  We don't want an outline or Stroke on our graphics
    oscP5 = new OscP5(this,8000);  // Start oscP5, listening for incoming messages at port 8000
   arduinoPort = new Serial(this, Serial.list()[0], 9600);    // Set arduino to 9600 baud
void oscEvent(OscMessage theOscMessage) {   //  This runs whenever there is a new OSC message
    String addr = theOscMessage.addrPattern();  //  Creates a string out of the OSC message
    if(addr.indexOf("/1/toggle") !=-1){   // Filters out any toggle buttons
      int i = int((addr.charAt(9) )) - 0x30;   // returns the ASCII number so convert into a real number by subtracting 0x30
      led[i]  = int(theOscMessage.get(0).floatValue());     //  Puts button value into led[i]
    // Button values can be read by using led[0], led[1], led[2], etc.
void draw() {
 background(50);        // Sets the background to a dark grey, can be 0-255
   if(led[1] == 0){        //  If led button 1 if off do....
    arduinoPort.write("r");    // Sends the character "r" to Arduino
    redLED = 0;        // Sets redLED color to 0, can be 0-255
 if(led[1] == 1){        // If led button 1 is ON do...
  arduinoPort.write("R");    // Send the character "R" to Arduino
  redLED = 255;        // Sets redLED color to 255, can be 0-255
fill(redLED,0,0);            // Fill rectangle with redLED amount
   ellipse(50, 50, 50, 50);    // Created an ellipse at 50 pixels from the left...
                // 50 pixels from the top and a width of 50 and height of 50 pixels
//----------------------------------end processing code------------------------------------
Ho installato le librerie su Processing e ho anche creato il programma OSC ma quando clicco il pulsante sul programma di OSC non succede niente. Come si potrebbe risolvere il problema?
simonenascivera
Prova a scrivere il programma ma anziche arduino usa la funzione print(..) per verificare che touch osc funzioni
LoadDuinoUNO
Ho semplicemente ricambiato il mio indirizzo IP del telefono e del PC e ora funziona
