Topic: Infinite loop at while(!client.available()) (Read 3620 times) previous topic - next topic
woodwax
Aug 21, 2015, 10:30 pm Last Edit: Aug 21, 2015, 11:51 pm by robtillaart
Hello
I running webserver on my ESP8266. Also its gets NTP time data from server in every 100 seconds, and have a Ticker with 10second cycle. Its going very well but sometimes at line:
Code: [Select]
  Serial.print(".");
  delay(1);
}// Wait until the client sends some data
It falls and only write out "." on serial port, infinite loop. Does anyone have ideas?
I attach part of my code.
robtillaart
change the while in an if  and only act when there is data
if (client.available() > 0)
   // process received data
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
nickgammon
Quote
Also its gets NTP time data from server in every 100 seconds ...
The internal clock isn't that inaccurate. You'll be IP blocked by the NTP server before you know it.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
SurferTim
#3
Aug 22, 2015, 12:30 am Last Edit: Aug 22, 2015, 12:37 am by SurferTim
Quote
If the server stalls or the connection breaks (fails), that will happen. You will need to implement some type of timeout feature to prevent the endless loop.
edit: It could also be a port scanner checking the ports on your device. Some do not bother to close the connection after establishing one.
woodwax
#4
Aug 22, 2015, 12:40 pm Last Edit: Aug 22, 2015, 12:40 pm by woodwax
Thank You very much for the answers, I implement a very simple time out and its going very well.
Code: [Select]
while(!client.available())   {
    Serial.print(".");
    delay(1);
    timeout++;
    if(timeout>10000) {Serial.print("INFINITE LOOP BREAK!");  break;}
    timeout=0;
Also I set NTP time refresh interval to about once per day.
