Topic: How to use the ADXL355 or GY-61 accelrometer (Read 49781 times) previous topic - next topic
zbot473
Aug 23, 2015, 02:22 am Last Edit: Aug 23, 2015, 02:24 am by zbot473
Though I used the GY-61, the ADXL355
Attach the pins to the shown on arduino. The code is attached. just open the serial monitor, upload the program and you're set!!
Im 11 years old, so be nice. :)
Code: [Select]
ADXL335
note:vcc-->5v ,but ADXL335 Vs is 3.3V
The circuit:
      5V: VCC
analog 1: x-axis
analog 2: y-axis
analog 3: z-axis
const int xpin = 1;                  // x-axis of the accelerometer
const int ypin = 2;                  // y-axis
const int zpin = 3;                  // z-axis (only on 3-axis models)
 // initialize the serial communications:
 int x = analogRead(xpin);  //read from xpin
 int y = analogRead(ypin);  //read from ypin
 int z = analogRead(zpin);  //read from zpin
float zero_G = 512.0; //ADC is 0~1023  the zero g output equal to Vs/2
                      //ADXL335 power supply by Vs 3.3V
float scale = 102.3;  //ADXL335330 Sensitivity is 330mv/g
                       //330 * 1024/3.3/1000
/*Serial.print(x);
Serial.print("\t");
Serial.print(y);
Serial.print("\t");
Serial.print(z);
Serial.print("\n");*/
Serial.print(((float)x - 331.5)/65*9.8);  //print x value on serial monitor
Serial.print("\t");
Serial.print(((float)y - 329.5)/68.5*9.8);  //print y value on serial monitor
Serial.print("\t");
Serial.print(((float)z - 340)/68*9.8);  //print z value on serial monitor
Serial.print("\n");
OH yeah GO India
Nishant_Sood
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Nico_TheDecoder
It is true that you describe, 5v into GY-61 (adxl335 + 3v3 LDO 662k on PCB).
LDO looks like a SMD transistor, but is lablet with the text "662K"
But lacking a 3v3 output from LDO to Aref, for more accurate readout.
I think that there must be other than me with this "problem", it can be solved easily, by soldering a wire on the output of the LDO 3v3 pin, but LDO 3v3 pin is small.
And there must be another solution, without buying another module.
If someone has an idea, hardware or software, all can be used.
kunalkalra2001
Hey Zbot,
Thank you so much for sharing this code.
Very helpful for current project. Before using this code according to my needs, can you please explain certain values, that you used.
Why you use 512 here? and
How you got this 102.3 value here?
And what is this calculation for : Serial.print(((float)x - 331.5)/65*9.8);
MajorProb
I guess the 512 is the requirement for the G-sensor zu be zero_G, since it ist the middle between 0-1023. It might be slightly more effective to set it as an Int since a float takes more space (just a recommendation).
The 102.3 is described in the code (actually 102.4).
I hope I could help
swapnilChaure
dnasun
For gyro stabilization.
Is there anyone who built a similar project ?
komal_embel
 please explain it appropriately
