Topic: Servo MG996R only rotates clockwise (Read 2466 times) previous topic - next topic
donimart
hi guys! i have a problem with my servo MG996R. i use following code
‪#‎include‬ <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos < 120; pos += 1) // goes from 0 degrees to 120 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 120; pos>=1; pos-=1) // goes from 120 degrees to 0 degrees
but the servo only rotates clockwise up to the end. any one can help me? thanks
robtillaart
Can you post a link to the datasheet of the servo?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
cyberjeff
I believe, but am not sure, that  the center is at 90. So, the sweep should be 30 to 150. you may wish to try it at 60 to 120, in case I am wrong. I'm not sure what happens to a servo pushed beyond it's limit, but I don't wan't a personal discovery moment on that!
zoomkat
Servo test code below that can be used to find the rotation limits of your servo. How are you powering the servo?
Code: [Select]
// zoomkat 3-28-14 serial servo incremental test code
// using serial monitor type a character (s to increase or a
// to decrease) and enter to change servo position
// (two hands required, one for letter entry and one for enter key)
// use strings like 90x or 1500x for new servo position
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include<Servo.h>
String readString;
Servo myservo;
int pos=1500; //~neutral value for continous rotation servo
//int pos=90;
  myservo.attach(7, 400, 2600); //servo control pin, and range if desired
  Serial.println("serial servo incremental test code");
  Serial.println("type a character (s to increase or a to decrease)");
  Serial.println("and enter to change servo position");
  Serial.println("use strings like 90x or 1500x for new servo position");
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    if(readString.indexOf('x') >0) {
      pos = readString.toInt();
    if(readString =="a"){
      (pos=pos-1); //use larger numbers for larger increments
      if(pos<0) (pos=0); //prevent negative number
    if (readString =="s"){
      (pos=pos+1);
    if(pos >= 400) //determine servo write method
      Serial.println(pos);
      myservo.writeMicroseconds(pos);
      myservo.write(pos);
  readString=""; //empty for next input
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
cyberjeff
I like it, +1 to you.
Code: [Select]
#include<Servo.h>
String readString;
Servo myservo;
//int pos=90;
      (pos=pos+1);
      myservo.write(pos);
donimart
tx all. i already found that the ground of the servo power should conected togather with arduinos ground. sorry if i have bad english, i'am indonesian.
Mahfuz097
I am also facing same problem. I need your brief suggestion.
DuaneDegn
If you're facing the same problem then connect the ground of the servo with the ground of the Arduino.
Did you try zoomkat's code?
