Topic: MIDI lib, controlling volume on ch 1 with pot (Read 4090 times) previous topic - next topic
FranPhony
Hello again.
I had no luck with the code for the keyboard above. I have made some progress with this bit of code from youtube
Code: [Select]
#define NUM_ROWS 3
#define NUM_COLS 8
#define NOTE_ON_CMD 0x91
#define NOTE_OFF_CMD 0x81
#define NOTE_VELOCITY 127
//MIDI baud rate
#define SERIAL_RATE 9600
// Pin Definitions
// Row input pins
const int row1Pin = 6;
const int row2Pin = 7;
const int row3Pin = 8;
// 74HC595 pins
const int dataPin = 9;
const int latchPin = 10;
const int clockPin = 11;
boolean keyPressed[NUM_ROWS][NUM_COLS];
uint8_t keyToMidiMap[3][8] ={
                                        36, 37, 38, 39,
                                        40, 41, 42, 43, 44, 45, 46, 47,
                                        48, 49, 50, 51, 52, 53,  54, 55
// bitmasks for scanning columns
int bits[] =
  B00000001,
  B00000010,
  B00000100,
  B00001000,
  B00010000,
  B00100000,
  B01000000,
  B10000000
  int note = 36;
  for(int colCtr = 0; colCtr < NUM_COLS; ++colCtr)
    for(int rowCtr = 0; rowCtr < NUM_ROWS; ++rowCtr)
      keyPressed[rowCtr][colCtr] = false;
      note++;
  // setup pins output/input mode
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(latchPin, OUTPUT);
  pinMode(row1Pin, INPUT);
  pinMode(row2Pin, INPUT);
  pinMode(row3Pin, INPUT);
  Serial.begin(SERIAL_RATE);
  for (int colCtr = 0; colCtr < NUM_COLS; ++colCtr)
    //scan next column
    scanColumn(colCtr);
    //get row values at this column
    int rowValue[NUM_ROWS];
    rowValue[0] = digitalRead(row1Pin);
    rowValue[1] = digitalRead(row2Pin);
    rowValue[2] = digitalRead(row3Pin);
    // process keys pressed
    for(int rowCtr=0; rowCtr<NUM_ROWS; ++rowCtr)
      if(rowValue[rowCtr] != 0 && !keyPressed[rowCtr][colCtr])
        keyPressed[rowCtr][colCtr] = true;
        noteOn(rowCtr,colCtr);
    // process keys released
      if(rowValue[rowCtr] == 0 && keyPressed[rowCtr][colCtr])
        noteOff(rowCtr,colCtr);
void scanColumn(int colNum)
  digitalWrite(latchPin, LOW);
  if(0 <= colNum && colNum <= 7)
    shiftOut(dataPin, clockPin, MSBFIRST, B00000000); //right sr
    shiftOut(dataPin, clockPin, MSBFIRST, bits[colNum]); //left sr
  digitalWrite(latchPin, HIGH);
void noteOn(int row, int col)
  Serial.write(NOTE_ON_CMD);
  Serial.write(keyToMidiMap[row][col]);
  Serial.write(NOTE_VELOCITY);
void noteOff(int row, int col)
  Serial.write(NOTE_OFF_CMD);
My keyboard consists of a 20 button matrix ( 3 x 8 ) and a 29 button matrix ( 4 x 8 ). I have been trying to get the 20 button matrix two work with this code, although my results are less than ideal.  As it is I get only three notes from each ground instead of 4 for ground 1 and 8 for grounds 2 and 3 each. So out of the 20 keys I only get three notes and I can change the value of those notes with the keytomidimap fuction but I can't get nabouring notes to work properly if at all.
Where am I going wrong here?
Also, can anyone tell me whether it is possible to use this bit of code with the midi library!?
FranPhony
I managed to get the keys working with this last bit of code. I then tried to structure it like the ondes sketch so that I can just add them together with minimal hassles. Here is my attempt
Code: [Select]
#include <MIDI.h>
#define NUM_ROWS 3
#define NUM_COLS 8
// Pin Definitions
// Row input pins
// 74HC595 pins
uint8_t keyToMidiMap[NUM_ROWS][NUM_COLS]={                  32, 33, 34, 35,
                                            36, 37, 38, 39, 40, 41, 42, 43,
                                            44, 45, 46, 47, 48, 49, 50, 51,
                                            52, 53, 54, 55,};
int bits[] =
  B00000001,
  B00000010,
  B00000100,
  B00001000,
  B00010000,
  B00100000,
  B01000000,
  B10000000
MIDI_CREATE_DEFAULT_INSTANCE();
void SendMIDI (char cmd, char data1, char DATA2) {
  Serial.write(byte (cmd));
  Serial.write(byte (data1));
  Serial.write(byte (DATA2));
void keyNotes()
  for(int colCtr = 0; colCtr < NUM_COLS; colCtr ++)
    for(int rowCtr = 0; rowCtr < NUM_ROWS; rowCtr ++)
  for (int colCtr = 0; colCtr < NUM_COLS; colCtr ++)
    //scan next column
    scanColumn(colCtr);
    for(int rowCtr=0; rowCtr<NUM_ROWS; rowCtr ++)
       SendMIDI (0x91, (rowCtr,colCtr), 127);
        SendMIDI (0x11,  (rowCtr,colCtr), 0);
    shiftOut(dataPin, clockPin, MSBFIRST, bits[colNum]); //right sr
    shiftOut(dataPin, clockPin, MSBFIRST, bits[colNum-8]); //right sr
  MIDI.begin(1);
void loop(){
  keyNotes ();
I am getting constants streams of note-ons with note values of 0 - 7. I don't think I'm calling the corresponding key number from 'keyToMidiMap' properly.. I'm out of ideas for today, help would be appreciated
