Topic: Slow Serial Port connection with processing (Read 5536 times) previous topic - next topic
steam229
Suddenly my Serial port connection got very slow, but only when dealing with processing. No problems on arduino console. The delay is huge and sometimes no communication happens even though it is established. This happened after two things that I think are not related: 1. Installed PlatformIO (PlatformIO.org); 2. Installed Processing3 (already tried the same example scripts over and over on different versions);
I'm running it on MacOsX.
Can you help me?
Thanks in Advance,
André
PaulS
A specific example on both ends would allow one of us to reproduce, or not, your problem.
What is Processing3?
steam229
#2
Sep 06, 2015, 08:13 pm Last Edit: Sep 06, 2015, 09:16 pm by steam229
I'm using the common examples that come along with processing and arduino ide.
Processing3 is the newest version.
In any of the examples it happens.
since the problem happens on base code examples that where working a month ago I can extrapolate that it is not a code problem.
Besides that, the delay doesn't happen on terminal view of the serial port.
That led me to conclude that it might be any conflict that derives from any recent installation or process currently running for which I need your guidance, opinions or suggestions to debug
thanks.
PaulS
Quote
Noitisnot.
Spaces matter.
I'd try uninstalling PlatformIO.
steam229
it does matter, you're totally right,
Thanks
steam229
Removed PlatformIO and nothing new.
Serial communication works perfectly with all the code examples from arduino and processing for SerialIO on arduino console and work really bad with loads of delay directly with processing on all versions.
Any idea of debug method?
Thanks again!
PaulS
Quote
Did I misunderstand something there? It seems to me that you said that serial communication between Processing and Arduino is both fast and slow.
I have two versions of Processing, and several different Arduinos, including a Mega and a Due. If you show a SPECIFIC example, and explain what I misunderstood from your (obviously frustrated) statement above, I'd be happy to try to reproduce the problem.
So far, all we've gotten though is a bunch of hand waving.
steam229
Thank you very much:
there is no need for a code example since it is not a code problem on any of the sides.
arduino leonardo<-> arduino ide console (works perfectly on both directions)
arduino leonardo <-> processing 3 (huge, almost one minute delay)
the code can be on both cases the arduino and processing code that you load from any of the serialIO native examples.
PaulS
Quote
Oh, good. I thought you said that you had a problem. I'm glad that you don't. On the other hand, I'm not all that thrilled that you've been jacking us around.
Quote
But, since you don't have a problem, I'm forced to assume that the delay is acceptable.
Moving on...
steam229
it is not a programming issue but it is still an issue.
I need help troubleshooting whatever is happening on my computer to cause this.
sorry I just noticed now that I'm on the wrong section... I'm very very very sorry!
steam229
Should I move this topic to the troubleshooting section?
If so, How is that done?
thanks
PaulS
Quote
Click any Report to Moderator link, and in the reason field, ask that it be moved. You probably can't report your own posts, but you can click the link in any reply that is not yours.
steam229
Help!
today I tried the communication with a different installation of processing 3 on Raspbian and delay happened again.
Can anyone help me debug this?
mac OsX or Raspbian + Processing 3 + any SerialIO library example code on both arduino and processing = Huge delay on communication
the same doesn't happen if debugging arduino on arduino ide terminal window.
Thanks!
PaulS
Quote
No. You know what you need to do if you want help.
steam229
Here are the Processing 3 examples, with which it doesn't work on both directions:
Simple Write (arduino side)
// Wiring/Arduino code:
 // Read data from the serial and turn ON or OFF a light depending on the value
 char val; // Data received from the serial port
 int ledPin = 4; // Set the pin to digital I/O 4
 pinMode(ledPin, OUTPUT); // Set pin as OUTPUT
 Serial.begin(9600); // Start serial communication at 9600 bps
 if (Serial.available()) { // If data is available to read,
 val = Serial.read(); // read it and store it in val
 if (val == 'H') { // If H was received
 digitalWrite(ledPin, HIGH); // turn the LED on
 digitalWrite(ledPin, LOW); // Otherwise turn it OFF
 delay(100); // Wait 100 milliseconds for next reading
Simple Write (Processing 3 side)
import processing.serial.*;
Serial myPort;  // Create object from Serial class
int val;        // Data received from the serial port
  size(200, 200);
  // I know that the first port in the serial list on my mac
  // is always my  FTDI adaptor, so I open Serial.list()[0].
  // On Windows machines, this generally opens COM1.
  // Open whatever port is the one you're using.
  String portName = Serial.list()[0];
  myPort = new Serial(this, portName, 9600);
void draw() {
  background(255);
  if (mouseOverRect() == true) {  // If mouse is over square,
    fill(204);                    // change color and
    myPort.write('H');              // send an H to indicate mouse is over square
  else {                        // If mouse is not over square,
    fill(0);                      // change color and
    myPort.write('L');              // send an L otherwise
  rect(50, 50, 100, 100);         // Draw a square
boolean mouseOverRect() { // Test if mouse is over square
  return ((mouseX >= 50) && (mouseX <= 150) && (mouseY >= 50) && (mouseY <= 150));
Simple Read (Arduino Side)
// Wiring / Arduino Code
// Code for sensing a switch status and writing the value to the serial port.
int switchPin = 4;                       // Switch connected to pin 4
  pinMode(switchPin, INPUT);             // Set pin 0 as an input
  if (digitalRead(switchPin) == HIGH) {  // If switch is ON,
    Serial.write(1);               // send 1 to Processing
  } else {                               // If the switch is not ON,
    Serial.write(0);               // send 0 to Processing
Simple Read (Processing Side)
  size(200, 200);
void draw()
  if ( myPort.available() > 0) {  // If data is available,
    val = myPort.read();         // read it and store it in val
  background(255);             // Set background to white
  if (val == 0) {              // If the serial value is 0,
    fill(0);                   // set fill to black
  else {                       // If the serial value is not 0,
    fill(204);                 // set fill to light gray
Has you can see this are Base well written examples, that per se don't cause delay.
What are the options in this cases, what else might go wrong that motivates this specific problem?
Thanks a lot
