Topic: WeMos D1 -- UNO like wifi board based ESP-8266 (Read 45963 times) previous topic - next topic
wemos
Sep 06, 2015, 11:37 am Last Edit: Sep 06, 2015, 11:41 am by wemos
We made a wifi board, named D1
  • based on the ESP-8266EX.
  • Arduino Compatible, you can use it on Arduino IDE.
  • 11 Digital I/O pins
  • 1 Analog Input pin
  • OTA -- Wireless Upload(Program)
  • On board switching power supply -- Max 24V input, 5V 1A output
more: http://www.wemos.cc/d1
robtillaart
Sounds nice,
the silk is missing some analog pins and I2C
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Chagrin
One analog input is all that the ESP8266 has available.
Isaac96
How about an analog mux? (That would probably take too many digital pins, though)
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
Tagem
#4
Nov 13, 2015, 06:52 am Last Edit: Nov 13, 2015, 07:01 am by Tagem
Hi!,
I try to install the wemos d1 files in the arduino IDE, however it fails with a file not found from the wemos.cc website.. The website itself seems down.
Does any one know another json link to get support in the arduino IDE?
Thanks!!
Deshke
#5
Dec 25, 2015, 02:30 am Last Edit: Dec 27, 2015, 08:01 pm by Deshke
Hello, ive got me a Wemos D1 and installed the arduino IDE + driver etc (followed all instructions from Wemos website) but the D1 does not get recognized in the IDE under ports after connecting it with a micro USB.
I already searched the web but couldnt find anything helpfull.
Ive tried with Windows 10 and with a Mac os x (El capitan). Someone has any suggestion please?
Thank you in advance.
edit: fixed it. Don't use latest version of Arduino IDE, only works with version 1.6.5
msveden
I have downgrade to IDE 1.6.5 but I still get the following messages:
warning: espcomm_sync failed
error: espcomm_open failed
My WeMos looks like the picture bellow with DIP switches and I think DIP 1 is suppose to be set to off when upload the code from IDE... But it doesn't matter how I put the switches. I still get the same error messages.
Please help me!
mpena
Hi folks!
Solution or El Captan: http://tzapu.com/making-ch340-ch341-serial-adapters-work-under-el-capitan-os-x/
See you!
Mauricio
bkenobi
I have a Wemos D1 on order and am curious about inturrupts.  I haven't found documentation suggesting that the EPS8266 does/does not support timers.  I have a project that I want to switch from an Uno with wired Ethernet shield to a D1 but it must support interrupts in order to properly receive RF (via RF69 module).
Gawan
what about I2C ?
It basically works with ESP8266 (NodeMCU), but on WeMos it fails all the time (for me).
Does it work ?
BR
Gawan
Gawan
ganesamoorthy
Arduino 1.6.7...will it be support for ESP8266 ....How do install the driver for the same?
filip_amator
Hello,
D1mini works fine with Arduino 1.6.8 and drivers&examples from wemos.cc website. I installed additional packages according to the instructions here http://www.wemos.cc/tutorial/get_started_in_arduino.html
using easiest way (without git).
HelloServer from ESP8266WebServer compiles without any errors/warnings and D1mini nicely connects to the home wifi router.
Deusy
#13
May 15, 2016, 10:00 pm Last Edit: May 15, 2016, 10:05 pm by Deusy
@ msveden.
Did you success in the meantime? I have the same board (shield) and try to upload a different FW (ESPeasy). But I always got the same message like you.
Maybe this topic can help you to be able to access with AT-commands:
https://forum.arduino.cc/index.php?topic=356174.new
pert
@ msveden.
This thread is for discussion of the WeMos D1: http://www.wemos.cc/Products/d1.html. This is an ESP8266 based board, not a shield(even though it has been incorrectly advertised as a shield in some Aliexpress listings I found). Please don't get off topic people. If you have questions or information regarding the shield shown in msveden's post please do so in the thread for that shield https://forum.arduino.cc/index.php?topic=356174.
