Topic: OpenWrt Chaos Calmer is final (Read 19652 times) previous topic - next topic
sscirrus
I'm having trouble with the latest release of Chaos Calmer on Yun (https://github.com/RedSnake64/openwrt-yun/releases/tag/ChaosCalmer_v1.5):
- Reflashed Yun with openwrt-1.5-ar71xx-generic-yun-kernel.bin and openwrt-1.5-ar71xx-generic-yun-rootfs-squashfs.bin.
- Moved openwrt-1.5-ar71xx-generic-yun-squashfs-sysupgrade.bin onto the microSD and upgraded the Yun.
- ERROR #1: Could not access arduino.local. Instead, had to go to the IP address and bypass Chrome's security warning: net::ERR_CERT_AUTHORITY_INVALID).
- Configured Yun to connect to my local WiFi and rebooted.
- SSH'ed into Yun using the IP address.
- ERROR #2: `opkg update` produces a long list of 'failed to decode signature, Signature check failed.'
- ERROR #3: I tried a list of basic installations I was able to do before:
Code: [Select]
opkg update
    opkg install bzip2
    opkg install unzip
    opkg install tar
    opkg install wget
    opkg install distribute
    opkg install bzip2
    opkg install pyopenssl
    opkg install python-openssl
    opkg install python-crypto
    opkg install python-bzip2
    opkg install python-ncurses
    easy_install pip
Apart from python-openssl and python-ncurses, ALL opkg commands return with 'Unknown package'.
easy_install returns with 'easy_install: not found'.
sscirrus
I thought I'd post an update for any future visitors - the reason for the failures to update opkg is because my router had IP filtering set up on that address, which was preventing the Yun from accessing internet.
Removing IP filtering allowed the Yun to access internet, and to successfully run `opkg update`.
millopapiarduino
Hi Scirrus
I have tride the sequence:
    opkg install bzip2  :)
    opkg install unzip   :)
    opkg install tar   :)
    opkg install wget  :)
    opkg install distribute  >:(
    opkg install bzip2
    easy_install pip
I'm stop at distribute
" Unknown package 'distribute'.
error:
 * opkg_install_cmd: Cannot install package distribute.
any suggestion ?
my target is to install PIP and the PAHO
