Topic: NRF24L01 capacitor problem!!! (Read 12320 times) previous topic - next topic
Grumpy_Mike
Can you be more specific than simply saying
Quote
but against the same problem
You said at the start:-
Quote
It loose signal very often so I soldered a 100uf ceramic capacitor and works pretty good but it rarely loose the signal again what can I do for this problem?
So what is the same?
We need to see now the full schematic, and your sketch for both send and receive and the errors you are getting.
DimitrisTzam
When I soldered 10uf  electrolytic capacitor parallel with 100nf  ceramic my sketch saws me on serial monitor more "radio no available "
groundFungus
The radios need a power supply capable of supplying 200mA at 3.3 Volts.  Caps will not fix a supply that can only supply 50mA.
DimitrisTzam
In other words I need a power supply
TomGeorge
Also a picture of your project thanks.
Tom..... :)
Everything runs on smoke, let the smoke out, it stops running....
DimitrisTzam
On pdf of nrf it says 14ma...
I'm from mobile and I don't know how to upload photos but I have connected nrf on arduino nano (it's clone from eBay )
Paul__B
dwightthinker
The 100K is not a multiplier. The K is the material the cap
is made from. It is most likely even smaller than 100nf. It is
most likely 100pf.
Electrolytics have poor high frequency response above a megahertz
or so. Tantalums are better but hard to find in sizes over 10uF for cheap.
Putting ceramics in parallel is typically done on electrolytics.
Dwight
