Topic: Why this shematic work bad? Please help! (Read 1 time) previous topic - next topic
wrdArduino
Good morning! Have a trouble, this shematic is true? :)
Have some problem with pin 12(maybe?)
Arduino usb always frozen(my code in forum programming)
HELP,HELP,HELP!!!
I have no options...
Grumpy_Mike
The diode is in the wrong place, it should be across the coil not in seriese with it.
That is probably causing the freezing.
That diagram is very poor. First it is on its side which makes it difficult to read in a mobile device because the device keeps putting the picture the "right" way up.
What size is that resistor?
wrdArduino
it should be across the coil not in seriese with it. ???
resistor is not lit!
Watcher
#3
Sep 15, 2015, 09:33 am Last Edit: Sep 15, 2015, 09:34 am by Watcher
Is pin2 controlling the relay coil? Why is the third pin (of the coil??) connected to 3.3v?
Arduino cannot directly drive relay coil anyway.
The diagram is not clear at all.
What are you trying to do??
wrdArduino
Pin 2 show open\close state of the device as a whole.
Adapter 12v 5A send impuls to coil across relay throw diod by 12 pin (open\close relay)!
I am not electronics!
Grumpy_Mike
Let us hope the resistor is not lit.
1) You need a diode across that induction coil not in series with it.
2) You need a transistor to drive the relay coil.
3) You need a diode across the relay coil.
4) You need a better translator that then one you have, your replies are barely comprehensible.
wrdArduino
Thanks to all, problem solved!
Shematic good, coding simple!!! :) from SerialEvent i removed DELAY and changed code!
Thanks to "experts" for help !
5) Grumpy_Mike напиши свой ответ на русском!
Grumpy_Mike
Quote
Shematic good,
нет
Поэтому задать вопрос , если вы не хотите , чтобы узнать,
raschemmel
#8
Sep 16, 2015, 11:25 pm Last Edit: Sep 16, 2015, 11:28 pm by raschemmel
Quote
Quote
5) Grumpy_Mike  Write your answer in Russian !
Quote
нет
Google Translate:
Quote
no
So ask the question if you do not want to know ,
Grumpy_Mike
Yes not quite right was it but you don't know if the word "why" was dropped on the way into Russian or on its return journey.
ApexM0Eng
Google translate feedback loops are pretty brutal.
wrdArduino
Thanks for help!
So it is heard your answer as -- :) brutal in my language!!!
raschemmel
#12
Sep 18, 2015, 09:26 am Last Edit: Sep 18, 2015, 09:35 am by raschemmel
In view of :
"I'm not electronics !"
is there really any point in telling the OP that the reason the diode should be in parallel with the coil instead of in series is that :
A- the diode drops 0.7 V
B- the diode is a "flyback diode" intenddd to shunt " back EMF"
C- the reason for using a transistor to drive the relay is to provide isolation between the arduino relay driving pin and the relay power.
