Topic: Is it possible to clean ICs with Pure Alcohol ? (Read 3454 times) previous topic - next topic
firashelou
hello guys,
i hope you all having a great weekend
i would like please to know if it is possible to clean the ICs chips from dust with pure Alcohol ?
Aiming for the unreachable !
my social website https://www.asserter.net
weedpharma
I have used isopropyl alcohol without problems.
Weedpharma
firashelou
Weedpharma
aha a more than 90%
well mine is 95% but it says Aqua and Alcohol so it has to be ethanol as google search showed
aarg
aha a more than 90%
Highly unlikely. The sale and labelling of such products are tightly regulated.
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
firashelou
what do you mean ? i did not understand what you mean ?
i just put some pure alcohol in a cup and i threw the Shift registers 959 inside and after a while i took them off and cleaned them with a small towel and now leaving it to dry a little
is that a good procedure to do or it will have a negative impact on the ICs ?
aarg
Alcohol will not damage the IC's. For your own health, treat it as a toxic chemical.
firashelou
ah ok gd because i cleaned the ICs with it
Boardburner2
hello guys,
depends on the alcohol
isppropyl alcohol  can work
Ethanol is subject to duty and very expensive.
Meths is a mixture of mostly ethanol and methanol to make it undrinkable methanol is very poisonous.
Meths contains an emetic to discourage you.
what do you want to clean off ?
firashelou
i am cleaning dust
the bottle i have doesn't say ! it says Pure Alcohol
and about the compositions it says : Aqua and Alcohol
that's all :/
Boardburner2
deonised or distilled water should work for that depending what the dust is and you thouroughly dry it.
does nnot an air blast work ?
firashelou
i dont have one,
i have the normal hair dryer which won't work
but anyway what i did is take a cup put some pure alcohol the one you can use on injuries or for cleaning and put some in the cup and after i threw the shifts inside and then take them out and dry it with tissue and left it to fully dry in the normal air
Paul__B
Well, somewhat poisonous.  The amounts cited are moderately difficult to ingest. :smiley-eek:
Not usually.  Generally a bitterantand possibly odorant.
Boardburner2
#12
Sep 28, 2015, 10:46 am Last Edit: Sep 28, 2015, 10:51 am by Boardburner2
There are fair few tourists who have bought cheap alcohol when travelling who would thoroughly disagree with that, a no of doctors as well.
In any case whatever the additive i find my local stuff leaves a residue so probably best not used for pcbs.
I'm not quite sure of the difference between a bitterent and an emetic but i'm not about to try and find out.
weedpharma
A bitterent make it nasty to ingest while an emetic make it easy to eject!   :)  :)  :)
Weedpharma
Boardburner2
grin.
As an addendum , industrial meths is an excellent solvent imo.
It does not have the residue associated with the over the counter.
Unfortunately eu taxation of alcohol encourages adulteration by criminal gangs and poisoning is too common.
This makes industrial meths extremely difficult to get.
