Topic: Sin() and other math calculacion (Read 11014 times) previous topic - next topic
mrax
I have problem with matematic.
when i calculate (with desktop calculator) sin(40)*85 result is 54,63
but
when i put this formula in arduino result is 63,33
I need result like desktop calculator. How
mrax
I find solutioin.
sin(radians (40))*85
econjack
Also, the math function usually require floating point numbers, so it's best to write the statement as:
  x = sin(radians (40.0))*85.0;
The use of the decimal point makes it clear that floating point calculations are required.
akbarkhan
#3
Sep 21, 2016, 05:04 pm Last Edit: Sep 21, 2016, 05:10 pm by akbarkhan
Here is the prototype of sin function of math.h library.
double sin(double x);
x : A floating point value representing an angle in radians.
If you have angle in degree then you can convert it to radian by multiplying it with (3.14/180). Hope it helps.
daljitgroup
thank you Mrax it is beneficial for me also.
