Topic: New Arduino Tian make Arduino out of bottom of the food chain. (Read 14521 times) previous topic - next topic
sonnyyu
FYI;-
The heart of Yún is CPU - AR9331, here is the market position of it.
AR9331 (MIPS 24k@400MHz, 1x1:1, 150Mbs/2.4GHz, PHY/100Mbs)
AR9341 (MIPS 74Kc@500Mhz, 2x2:2, 300Mbs/2.4GHz, PHY/100Mbs)
AR9344 (MIPS 74Kc@600MHz, 2x2:2, 300Mbs/2.4GHz, 450Mbs/5GHz, PHY/1Gbs)
QCA9558 (MIPS 74Kc@720MHz, 3x3, 450Mbs/2.4GHz, 1300Mbs/5GHz, PHY/1Gbs)
It is already on bottom of the food chain.
Arduino Tian:
AR9342:MIPS 74Kc@560MHz, 2.4GHz, 5GHz
http://www.arduino.org/products/boards/4-arduino-boards/arduino-tian
jessemonroy650
Arduino Tian:
AR9341:MIPS 74Kc@560MHz, 2.4GHz, 5GHz
https://www.arduino.cc/en/Main/ArduinoBoardYun
Difference I see:
  • Built in BLE (Bluetooth)!!!
  • 14 Digital input (20 on Yun)
  • 6 Analog input (12 on Yun)
  • 7mA (40mA on Yun, I think) DC current per I/O pin
Wow, BLE and lower power. Hmmm, but I need more analog I/O!?!
Anyone else?
Jesse
q2dg
The main difference for me is Tian replaces ATmega32U4 (Yun's micro) by SAMD21 (Zero's micro).
sonnyyu
And AR9342:MIPS 74Kc@560MHz, 2.4GHz, 5GHz (dual band) v.s. AR9331 MIPS 24Kc@400MHz, 2.4GHz
MIPS32 24 Kc  delivers a performance of 1.6 DMIPS/MHz and 3.1 Coremarks/MHz.
MIPS32 74 Kc  delivers a performance of 1.93 DMIPS/MHz and 3.48 Coremarks/MHz
AR9342:MIPS 74Kc@560MHz run 2 times  faster than AR9331 MIPS 24Kc@400MHz.
sonnyyu
Difference I see:
Anyone else?
Jesse
Apple to apple comparison:
Yun:
Analog Input Channels:12, 10 bit ADC channels
Analog Output Pins:0
Tian:
Analog Input Pins:6, 12-bit ADC channels
Analog Output Pins:1, 10-bit DAC
Tian is far better than Yun if you need analog I/O.
mart256
Wow, a beautiful board. I wonder if they will improve the bridge library. And I didnt see a microsd socket.
sonnyyu
eMMC Flash 4 GB.
sonnyyu
USB OTG port:
Quote
USB On-The-Go, often abbreviated to USB OTG or just OTG, is a specification first used in late 2001 that allows USB devices such as digital audio players or mobile phones to act as a host, allowing other USB devices such as USB flash drives, digital cameras, mice or keyboards to be attached to them. Use of USB On-The-Go allows those devices to switch back and forth between the roles of host and client devices. For instance, a mobile phone may read from removable media as the host device, but present itself as a USB Mass Storage Device when connected to a host computer.
In other words, USB On-The-Go introduces the concept of a device performing both master and slave roles - whenever two USB devices are connected and one of them is a USB On-The-Go device, they establish a communication link. The device controlling the link is called the master or host, while the other is called the slave or peripheral.
https://en.wikipedia.org/wiki/USB_On-The-Go
sonnyyu
 Arduino Yún : Yún in Chinese means cloud.
Arduino Tian: Tian in Chinese means sky.
ShapeShifter
Better if you need the extra two bits of resolution, but not better if 10 bits is good enough and you need more channels.
eMMC Flash 4 GB.
Not the same as an SD card: it's smaller, and not removable. That means you can't swap out the card to log more data, copy the files to another computer, or prevent wearing out frequently updated files.
Increased raw power is enticing: but not every application needs maximum processing power, and with the increased power comes some trade-offs that might eliminate it from some some applications.
sonnyyu
Far better here is Tian:1, 10-bit DAC v.s. Yun: None
sonnyyu
It is true.
On other side micro SD slot has reliability problem, we saw so many threads here already.
mart256
Thats what I meant with the microSd. But theres the usb host for flash drives.
ShapeShifter
Again, better only if you need it. If you don't need it, the feature is meaningless.
sonnyyu
Arduino Tian:
2.4 GHz wifi band dirty crowd:
5 GHz  wifi band is super clean:
Channel 36-48
Channel  149-165
