Topic: New Arduino Tian make Arduino out of bottom of the food chain. (Read 14520 times) previous topic - next topic
sonnyyu
New Arduino Tian come with two standard antenna connector, one for 2.4 GHz and an other for 5 GHz.
extended wifi range could be easily by use antenna. 24 dBi antenna will make wifi range from 100m  to 1600m.
Friis Transmission Formula with Propagation Law
  • R = Maximum range for communication link
  • N = Propagation Law (N=2 for line-of-sight, N=4 for urban environments)
  • PT= Transmit power
  • GT= Total antenna gain
  • λ = Wavelength
  • PR= Receiver sensitivity
  • FM= Fading margin
if in urban environments;-
  • Every 12 dBm receiver sensitivity gain will be double the distance.
  • Every 12 dBi antenna gain will be double the distance.
  • Every 12 dBm Transmitter power gain will be double the distance.
in line of sight environments;-
  • Every 6 dBm receiver sensitivity gain will be double the distance.
  • Every 6 dBi antenna gain will be double the distance
  • Every 6 dBm Transmitter power gain will be double the distance.
http://forum.arduino.cc/index.php?topic=175577.msg1304059#msg1304059
jessemonroy650
::::SNIP::::
@sonnyyu,
Can Yun use external antenna?
Jesse
sonnyyu
@sonnyyu,
Jesse
Yes, with some kind of difficulty (hack).
Yún: no antenna connector but special connector MM8430-2610 for calibration of AR9331.
https://forum.arduino.cc/index.php?topic=188976.msg1470200#msg1470200
Tian: two standard antenna connectors, one for 2.4 GHz and an other for 5 GHz.
jessemonroy650
Thanks.
Lappofant
Wow, a beautiful board. I wonder if they will improve the bridge library. And I didnt see a microsd socket.
Arduino.org provides a new library called "Arduino Ciao" that runs on the Yun. I knew it at last LinuxCon in Dublin few days ago. I tried ciao and it seems to be faster and simplier than the standard bridge. Ciao is also plugin based, but at the moment it supports few protocols though.
Some in deep info are available at http://labs.arduino.org/Ciao
mart256
Is the Ciao implemented in linux, as bridge? Now I cant check the ciao documentation.
Lappofant
Yes of course, it's mandatory to allow interaction with high-level communication protocols easily. The library on the sketch side is really lightweight to reserve more memory to the sketch implementation, it's quite easy to use too. It take me less than an hour to master it. Most of the work is done on the Linux side in a transparent way. The only part a bit tricky is to configure "ciao connectors", because you need to edit a file in the Linux part, but only the first time or when you need to change connection parameters.
jessemonroy650
@mart256
As ShapeShifter pointed out in another thread. Ciao is at Arduino.org, the other part of the company - not talking to this part.
Jesse
Lappofant
@mart256
Jesse
Yes, it's true. This library is at Arduino.org, but try to be more open, if it works better, why not try?
Bye
Lappo
te36
Tian has no PoE option. Not useable for me ;-( Really sad. Why did they do it...
sonnyyu
Work arround: PoE splitter & injector
sonnyyu
Arduino Yun's ethernet: 10/100 Mbps
Arduino Tian's ethernet: 10/100/1000 Mbps
The rest is simply math problem.
Gernby
is the Tian actually available for purchase anywhere?
sonnyyu
Arduino Yún : Yún in Chinese means cloud.
Arduino Tian: Tian in Chinese means sky.
in Chinese Yún is a subset of Tian.
tim9510019
Hi all:
Can TensorFlow be installed on Arduino Tian?
If it works, maybe some machine learning robots can be made.
It will be really cool.
