Topic: Tiny 8-pin connector (Read 2747 times) previous topic - next topic
jboyton
What's the smallest 8-pin connector available? It's for occasional use but it must be easy to insert/remove whatever cable it would accept.
Is it FFC?
larryd
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
jboyton
"About 8,460,000 results"
Thanks for narrowing it down for me. :-)
septillion
That's how narrow you're search criteria are... What's small? What currents? Voltages? Hand solder? etc
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
jboyton
#4
Sep 30, 2015, 07:15 pm Last Edit: Sep 30, 2015, 07:16 pm by jboyton
Fair enough.
3mA, 3.3V. Hand solder.
Size is the question, but no larger than 10x5x5 mm.
larryd
Sorry, I thought the criteria you set out was vague.
I am sure if you look at some of the offerings on the page you can come to a decision.
No technical PMs.
larryd
How about 4 by 4 JST or DuPont connector?
No technical PMs.
larryd
Is this cable to cable or cable to chassis?
No technical PMs.
larryd
#8
Sep 30, 2015, 07:39 pm Last Edit: Sep 30, 2015, 07:40 pm by LarryD
You can make your own if it is cable to cable.
Get 8 male pins, 8 female pins, solder to wires, heat shrink each pin, then heat shrink the group of 8.
You can polarize the connector by having 1 male and 7 female then 1 female and 7 male.
No technical PMs.
jboyton
Okay, it was a dumb question. I don't know what's available and couldn't pick a JST or DuPont connector out of a lineup. I suppose it was like asking how you program an Arduino.
I want to be able to occasionally connect a cable with 8 wires to an AVR that is on a small PCB. It's the connector on the PCB that I want to be of minimum length, width and height. An FFC connector is one possibility but I'm sure there are many others.
larryd
I have used 4X4 IDC, JST and DuPont.
These all are a good choice.
No technical PMs.
dannable
At the risk of being accused of a thread hijacker  ;)  is there a 1mm pitch connector similar to the DuPont style that can be hand crimped? I tried Element 14 but got lost in the sheer variety available, and all the 1mm stuff seemed to be for pcb mounting whereas I want cable fix.
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
jboyton
And you can find these in 10 x 5 x 5 mm size or less?
@dannable: Hijack away.
Boardburner2
#13
Sep 30, 2015, 08:18 pm Last Edit: Sep 30, 2015, 09:23 pm by Boardburner2
you could take a look at jst series connectors.
Be aware though that once you go below dupont size the crimps get very fiddly and the required crimp tools get very expensive.
Addendum.
Professional crimp dies can cost 400.
Pololu do a crimp for 40 which is ideal for dupont.
They can be used to do an acceptable crimp on jst though.
Its fiddly precise positioning and two crimping operations are needed.
larryd
Measured DuPont.
10mm long, 5mm wide and 15mm long (in the direction of the cable).
No technical PMs.
