i have found something similar. It is called DMS - "Dehnmessstreifen" and they use usually 1 or 2 channel telemetry for that. But the application seems a bit difficult. I will look into it. I have doubts. If it is really cheap and still accurate, why dont we see DMS applications everywhere? Are you familiar with DMS applications? What is best for my case? whats the difference between half bridge and full bridge strain gauges? And still, calibration is a main problem.
Actually i have thought about it, but i am still not sure how i measure it correctly. I mean DC electric motor doesnt have equal input and output. I could measure the rotation speed and do some calculations instead of adding another motor to do same calculations. Do you have any idea how i eliminate the deviation and possible measuring errors? I have seen some DC eletric bike motors with integrated torque sensor but i have no idea how do they work. What do you think, are they usuable for this task?
By the way, only one shaft has that rotational speed value. Most of the sensors have limited rotational speed values. For this reason i wrote only maximum values of different shafts which i want to test.
i am talking about rotating torque readings. Your idea sounds interesting. But i have several possible problems about this one. All these shafts are rotating on water. It is kinda hydro electric generator which floats on water. It isnt stable because of that. I cant imagine if i can eliminate it. But i will look into that too, maybe i can find a way. Otherwise i can use it while i test it in my garage.
I haven't found a solution yet, but i am thankfull for all these ideas. I will look into these. But i can use every new perspectives. Don't hesitate to write or ask.
I want to measure torque on rotating shaft. After hours of searching i could not find any option which doesnt cost a fortune. Existing sensors with data loggers, as a complete solution, are expensive.
That doesn't surprise me - its hard measuring the force on something you cannot connect to.
You can get fairly cheap wireless modules, but you'll have to do the design yourself and probably
need strain guage(s), amps, battery and wireless TX all in miniature packages...
If it has a shaft of some length, two magnets and two hall zero crossing sensors
could be calibrated to measure running torque.
The twist of the mounting can be used to measure torque.
Dwight
The magnets idea is interesting, but I doubt very sensitive.
Perhaps having a reasonably high resolution encoder on each end of the shaft would
be much more sensitive to small torsional strains (a large torsional strain might be
a bit risky, allowing for shaft failure, unwanted torsion oscillations).
You would then read from both encoders and record the difference in counts, which would
provide a discrete indication of torsion angle and hence torque.
The down side is that any shaft capable of 75 Nm is probably too fat for any cheap encoder
(5mm and 6.35mm are common sizes for cheap encoders).
MarkT:
For that you can always use a gear and do a indirectamente reading with the encoder attached to the smaller shaft
MarkT:
So just reading this I just wanted to add something. The magnets idea is not a bad idea and they are very sensitive. I know this since I am also researching torque measuring devices and the magnets are used quite often. The are used in a device called hall sensor which are used for measuring change in angular position of a shaft by determining the change in magnetic flux produced by the magnetized shaft or magnets attached to the shaft.
I have read through this topic and I also am faced with a problem.
Just to paint a picture. I am a fourth year mechanical engineering student from Stellenbosch University (South Africa). I am busy with my final year project which is as follows: "Develop a system to measure the torque on the shaft of a turbocharger".
While in essence it doesn't sound to hard, there are quite a few obstacles. Firstly the systems sound preferably work up to 30 000 rpm which eliminate using slip rings or any contact system. Secondly there isn't much free space on an assembled turbocharger for mounting any systems.
For this reason I have simplified the system by not going up to 30 000 rpm but maybe near 3000 rpm. Also I am going to have my own shaft machined and fitted with the compressor and turbine from and existing turbocharger.
So after all of this I actually need to get to my questions. I thought of using to gap sensors (or optical encoders), one of each end of the shaft, then by measuring the difference in time that it takes for each sensor to get a reading and having the rotational speed, one can determine the torsion angle of the shaft.
In theory this seems to be a viable option. Does anyone have any advice for me on how to do this. I do not have much programming skill and really want to use an arduino. so I need info on how fast arduinos can log data and what the max interrupt speed of and arduino is. Also what functions should I used to log the time at which the arduino receives the sensed information?
If anyone has any advice I would deeply appreciate it.
The shaft has to be slender to allow significant twisting at the torque levels used, which of course
adds elasticity in the system, which may have consequences. But it also has not to break or whip!
I suspect metal is a poor choice, perhaps delrin is a reasonable material - machinable, much lower
modulus, so can be a more reasonable proportions. However turbines run hot, so this may be
incompatible...
Another approach would be some sort of torsional spring arrangement joining the shaft ends.
Sorry to grave dig.
Could you not use a liner effect?
Have a shaft off the rear of the motor through a bearing and out to a second bearing a specific distance on a swivel; then measure the length from the motor to the end of the shaft?
one of my friends has gone through a similar problem with the usage of the rotary shaft to shaft torque sensor. He used strain gauge instead of the rotatory shaft. With strain gauges bonded to the shaft, the shaft becomes the transducer. Secondly, the shaft to be calibrated, a process that usually involves loading the shaft statically and tabulating the results. This is relatively easy to do in small systems, but as loads and shaft size increase, it becomes an onerous task. Selecting a location for the strain gauges, mounting them carefully and protecting them become problematic for users inexperienced in such techniques. Outside contractors are usually available through the torque sensor suppliers for most applications and locations.
Thank You.
Datumelectronics:
Thank You.
Another method is to calibrate the output using the properties of the shaft. There are some uncertainties related to the parameters used in the calculator, but it is still much more accurate than motor/current. TorqueTrak 10K Calculator English - Binsfeld
Binsfeld Engineering (Rotary Torque Sensors & Shaft Power Meters | Binsfeld) offers easy to use torque telemetry systems that use RF transmission from the strain gage bonded to the shaft. They also offer lease options and university discounts for a fraction of the cost of a new system.
