Topic: Connecting Arduino with Microsoft ACCESS (Read 2463 times) previous topic - next topic
5-RENI
Oct 08, 2015, 06:10 am Last Edit: Oct 08, 2015, 06:12 am by 5-RENI
Hi every brody.
Does any one know if there it´s possible to connect Arduino UNO with a Data Base on Microsoft ACCESS?
I need to see de DATA of a temperature sensor, and if one botton is HIGH or LOW with a binnary code (1=HIGH and 0=LOW)
regards!!!
Nick_Pyner
It may be possible to do it with Access. It is possible to do it directly with older versions of Excel using the macro PLX-DAQ. The date can also be recorded and timestamped by a terminal programme for subsequent use elsewhere.
5-RENI
Thanks Nick_Pyner for reply my doubt!
The main problem is how program inside ACCESS for introduce the DATA from Arduino
And I need to put a library in to the ARDUINO for connect it with ACCESS?
 I will check with PLX-DAQ...
Again thanks for help!
Greetings
Nick_Pyner
Probably not, just serial print.
